[ NZBHydra2 ] Meta search for newznab indexers and torznab trackers
Post by outkastm » 10 Dec 2021, 07:48
About: https://github.com/theotherp/nzbhydra2
Category: Download
Applicable models: TerraMaster x.64 series
Applicable TOS 4.x: 4.1.27 or later versions
Applicable TOS 5.x: 5.1.12 or later versions
App download: https://tmnascommunity.eu/download/nzbhydra2/
Required packages:
OpenJDK17 > 17.0.2.0
http(s)://yournasip:port/modules/NZBHydra2/www
About:
NZBHydra 2 is a meta search for newznab indexers and torznab trackers. It provides easy access to newznab indexers and many torznab trackers via Jackett. You can search all your indexers and trackers from one place and use it as an indexer source for tools like Sonarr, Radarr, Lidarr or CouchPotato.
Major Features
Searches Anizb, BinSearch, NZBIndex and any newznab compatible indexers. Merges all results, filters them by a number of configurable restrictions, recognizes duplicates and returns them all in one place
Add results to NZBGet or SABnzbd
Support for all relevant media IDs (IMDB, TMDB, TVDB, TVRage, TVMaze) and conversion between them
Query generation, meaning a query will be generated if only a media ID is provided in the search and the indexer doesn't support the ID or if no results were found
Compatible with Sonarr, Radarr, NZBGet, SABnzbd, nzb360, CouchPotato, Mylar, LL, Sick Beard, Jackett/Cardigann, Watcher, etc.
Search and download history and extensive stats. E.g. indexer response times, download shares, NZB age, etc.
Authentication and multi-user support
Automatic update of NZB download status by querying configured downloaders
RSS support with configurable cache times
Torrent support:
For GUI searches, allowing you to download torrents to a blackhole folder
A separate Torznab compatible endpoint for API requests, allowing you to merge multiple trackers
Extensive configurability
Save torrents in a black hole folder; Torznab API endpoint
Migration of database and settings from v1
