[ DokuWiki ][ 1.00.00 ] A simple to use and highly versatile Open Source wiki
About: https://www.dokuwiki.org/dokuwiki
Category: Business
Last version: 1.00.00
Applicable models: TerraMaster x.64 series
Applicable TOS: 4.1.27 or later versions
App download: https://bit.ly/39JLs5h
Required packages:
apache24 > 2.4.51.0
http(s)://yournasip:port/modules/DokuWiki/www
After first installation, access web Interface at http://yournasip:13000/install.php to complete the setup.
When setup is done, restart the server to delete install.php file
About
DokuWiki is a popular choice when choosing a Wiki software and has many advantages over similar software.
Easy to install and use
Low system requirements
Built-in Access Control Lists
Large variety of extensions
Over 50 languages supported
Device independent
Open Source
Re: [ DokuWiki ][ 1.00.00 ] A simple to use and highly versatile Open Source wiki
initial version added
