qBittorrent search plugins issue
pPier
Post by pPier »
Hi mate,
I'm trying to configure qBittorrent (4.1.7) on my TM F2-221 (TOS 4.2.15).
Python updated to version 3.6.3
I've been able to add just only "Linux Tracker" search engine but several others seems not be supported, why so?
(I) 2021-09-23T15:51:31 - Python detected, executable name: 'python3', version: 3.6.3
(I) 2021-09-23T15:52:32 - Plugin one337x is not supported.
(I) 2021-09-23T15:52:55 - Plugin bt4g is not supported.
(I) 2021-09-23T15:53:10 - Plugin btmulu is not supported.
(I) 2021-09-23T15:53:31 - Plugin elitetorrent is not supported.
(I) 2021-09-23T15:53:52 - Plugin extratorrent is not supported.
(I) 2021-09-23T15:54:13 - Plugin maxitorrent is not supported.
All search plugins are from the unofficial github page.
Is there a way to add the search engines that I need?
Thanks for your support
Re: qBittorrent search plugins issue
Hi! This article may be helpful to you.
viewtopic.php?f=37&t=1730&hilit=qbittorrent
pPier
Post by pPier »
HI TMsupport,
resolved thanks a lot!
