[ Duplicati ] Store securely encrypted backups on cloud storage services!
About : https://www.duplicati.com/
Applicable models: TerraMaster x.64 series
Applicable TOS5: 5.0.170 or later versions
App download: https://tmnascommunity.eu/download/duplicati/
Required packages:
ModBase1 > 1.00.10.1
mono > 6.12.0.122.0
http(s)://yournasip:port/modules/Duplicati/www
About
Many Backends
Duplicati works with standard protocols like FTP, SSH, WebDAV as well as popular services like Microsoft OneDrive, Amazon Cloud Drive " S3, Google Drive, box.com, Mega, hubiC and many others.
Features
Backup files and folders with strong AES-256 encryption. Save space with incremental backups and data deduplication. Run backups on any machine through the web-based interface or via command line interface. Duplicati has a built-in scheduler and auto-updater.
Free software
Duplicati is free software and open source. You can use Duplicati for free even for commercial purposes. Source code is licensed under LGPL. Duplicati runs under Windows, Linux, MacOS. It requires .NET 4.5 or Mono.
Strong encryption
Duplicati uses strong AES-256 encryption to protect your privacy. You can also use GPG to encrypt your backup.
Built for online
Duplicati was designed for online backups from scratch. It is not only data efficient but also handles network issues nicely. E.g. interrupted backups can be resumed and Duplicati tests the content of backups regularly. That way broken backups on corrupt storage systems can be detected before it’s too late.
Web-based user interface
Duplicati is configured by a web interface that runs in any browser (even mobile) and can be accessed - if you like - from anywhere. This also allows to run Duplicati on headless machines like a NAS (network attached storage).
Madvic
Spain
Re: [ Duplicati ][ 2.0.6.3.0 ] Store securely encrypted backups on cloud storage services!
Post by Madvic »
I need help here as I get the following message when trying to install Duplicati:
Error! the file is incorrect and cannot be installed
I'm using the last TOS 5 version
Regards
crisisacting
Post by crisisacting »
{L_BUTTON_AT}Madvic
The posted build is not TOS 5 compliant, hence that error.
Will be ported to TOS5 asap
Re: [ Duplicati ] Store securely encrypted backups on cloud storage services!
added TOS5 version
Madvic
Spain
Post by Madvic »
I just tried to install and it can't be enabled: I get "Operation Failed" pop up when trying to enable.
TOS version is 5.0.176
Duplicati2 version is 2.0.6.3.0
Cant reproduce it, here it start correctly.
Try to reboot your NAS
Madvic
Spain
Post by Madvic »
Not working even after restarting TNAS.
I downloaded the file again just to be sure it wasn't corrupted.
I'll check again this evening.
Do you have a Volume1 available ?
If Volume1 is available, try to create a folder MOD_CONFIG on Volume1
