Node update
fanomenal
Node update
Post by fanomenal »
How do I install the latest release of node.js please - I tried searching but couldn't find any details
I have an F2-210
HRuffalo
Re: Node update
Post by HRuffalo »
I installed both on 18.04 using apt and currently got node.js 8.x.x and npm 6.x.x, both of which I'm sure are behind. I code in React and Angular so current or latest versions would be preferred.
fanomenal
Re: Node update
Post by fanomenal »
HRuffalo wrote: 21 Sep 2021, 21:38 I installed both on 18.04 using apt and currently got node.js 8.x.x and npm 6.x.x, both of which I'm sure are behind. I code in React and Angular so current or latest versions would be preferred.
Node.js 8.17.0 was the last 8.x.x and was released on 2019-12-17. Current is v16.x.x
I also code with Angular and React but require an update of Node
