[ AirsonicAdvanced ] Free, web-based media streamer
About : https://github.com/airsonic-advanced/airsonic-advanced
Applicable TOS5: 5.0.170 or later versions
App download: https://tmnascommunity.eu/download/airsonicadvanced/
Required packages:
OracleJRE11 > 11.0.12.0
http(s)://yournasip:port/modules/AirsonicAdvanced/www - TOS4
http(s)://yournasip:port/AirsonicAdvanced - TOS5
What is Airsonic-Advanced?
Airsonic-Advanced is a more modern implementation of the Airsonic fork with several key performance and feature enhancements. It adds and supersedes several features in Airsonic.
What is Airsonic?
Airsonic is a free, web-based media streamer, providing ubiquitous access to your music. Use it to share your music with friends, or to listen to your own music while at work. You can stream to multiple players simultaneously, for instance to one player in your kitchen and another in your living room.
Airsonic is designed to handle very large music collections (hundreds of gigabytes). Although optimized for MP3 streaming, it works for any audio or video format that can stream over HTTP, for instance AAC and OGG. By using transcoder plug-ins, Airsonic supports on-the-fly conversion and streaming of virtually any audio format, including WMA, FLAC, APE, Musepack, WavPack and Shorten.
If you have constrained bandwidth, you may set an upper limit for the bitrate of the music streams. Airsonic will then automatically resample the music to a suitable bitrate.
In addition to being a streaming media server, Airsonic works very well as a local jukebox. The intuitive web interface, as well as search and index facilities, are optimized for efficient browsing through large media libraries. Airsonic also comes with an integrated Podcast receiver, with many of the same features as you find in iTunes.
Re: [ AirsonicAdvanced ][ 11.0.0.210825 ] Free, web-based media streamer
initial version is ready
Re: [ AirsonicAdvanced ][ 11.0.0.211119 ] Free, web-based media streamer
up to 11.0.0.211119
Re: [ AirsonicAdvanced ][ 11.0.0.211209 ] Free, web-based media streamer
up to 11.0.0.211209
Re: [ AirsonicAdvanced ][ 11.0.0.220128 ] Free, web-based media streamer
up to 11.0.0.220128
Re: [ AirsonicAdvanced ][ 11.0.0.220418 ] Free, web-based media streamer
up to 11.0.0.220418
matt_30
Post by matt_30 »
I am very greatful to find this as i could not get it working as a compose scirpt :D
Has anyone been able to get this working?
the url ...../modules/AirsonicAdvanced/www brings up an internal server error and when i attempt to add folders the path returned py the pwd command on a command prompt give me a 'path not found' error.
im wondering if i am missing a decalaraion of a folder path somewhere.
are you sure the media is located to that path ?
No issues here
wayneeden
Post by wayneeden »
{L_BUTTON_AT}outkastm
could you give me another link for download
cause i can't download,thanks
Re: [ AirsonicAdvanced ] Free, web-based media streamer
added TOS5 version
