[wsdd2][ 1.8.7.0] WSD/LLMNR Discovery/Name Service Daemon
About : https://github.com/Netgear/wsdd2
Applicable models: TerraMaster x.64 series - Last version: 1.8.6.0
Applicable models: TerraMaster arm series - Last version: 1.8.7.0
Applicable TOS: 4.1.27 or later versions
App download: https://bit.ly/3RZMbks
Required packages:
http(s)://yournasip:port/modules/wsdd2/www
With Microsoft turning off SMB1 feature completely on Windows 10, any Samba shares on the local network become invisible to Windows 10 computers. That's due to the fact that SMB1 is required for Computer Browser service to function.
Newer Windows systems can use WSD (Web Services for Devices) to discover shares hosted on other Windows computers while Linux systems normally utilize mNDS/DNS-SD for service discovery. Microsoft is moving to support mDNS/DNS-SD, but not yet there.
The primary purpose of this project is to enable WSD on Samba servers so that network shares hosted on a Unix box can appear in Windows File Explorer / Network.
NOTE: Make sure there is no firewall rule blocking WSD multicast address 239.255.255.250 and ff02::c, protocol UDP port 3702. Unicast SOAP HTTP WS-Discovery responder listens on TCP port 3702.
LLMNR responder listens on multicast 224.0.0.252 / ff02::1:3 UDP port 5355 and unicast TCP port 5355.
MisterXY
Germany
Re: [wsdd2][ 1.8.6.0] WSD/LLMNR Discovery/Name Service Daemon
Post by MisterXY »
Hello, is it possible to build it for the ARM version?
Thx
marryjanes
Post by marryjanes »
Thank you very much. Please let me know if you can make it for the ARM version
Typeracer must try racing game
MisterXY
Germany
Post by MisterXY »
you can also install entware and install via opkg wsdd2.
Re: [wsdd2][ 1.8.7.0] WSD/LLMNR Discovery/Name Service Daemon
added arm version (to test)
