[ ffmpeg ] Record, convert and stream audio and video
sanctimon
Re: [ ffmpeg ] Record, convert and stream audio and video
Post by sanctimon »
Where is it located in TOS 5? I would like to point my Docker JellyFin installation to it.
Spider
Post by Spider »
Hi All,
I am trying to set up Jellyfin 10.8.9.1 and have not been able to enable it.
I am using F4-220 running version 5.1.24.00324
I installed ModBase1 version 1.00.15 and FFMPEG version 4.4.3.0 in that order.
What is it that I am missing?
Thank you
send the log files from
/home/superuser/MOD_CONFIG/Jellyfin/Jellyfin_start.log
/home/superuser/MOD_CONFIG/Jellyfin/log/log_*.log
Spider
Post by Spider »
27/03/23 22:28:14 The main volume is /Volume2
27/03/23 22:28:14 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
27/03/23 22:28:14 Will run as user: jellyfin and group: media
start-stop-daemon --start -c jellyfin -b --exec /Volume1/@apps/Jellyfin/bin/program/jellyfin -- -d /home/Over/MOD_CONFIG/Jellyfin/data -C /home/Over/MOD_CONFIG/Jellyfin/cache -c /home/Over/MOD_CONFIG/Jellyfin/config -l /home/Over/MOD_CONFIG/Jellyfin/log --ffmpeg /usr/local/ffmpeg/sys/bin/ffmpeg
27/03/23 22:30:22 The main volume is /Volume2
27/03/23 22:30:22 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
27/03/23 22:30:22 Will run as user: jellyfin and group: media
27/03/23 22:38:58 The main volume is /Volume2
27/03/23 22:38:59 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
27/03/23 22:38:59 Will run as user: jellyfin and group: media
27/03/23 22:39:10 The main volume is /Volume2
27/03/23 22:39:11 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
27/03/23 22:39:11 Will run as user: jellyfin and group: media
27/03/23 22:43:55 The main volume is /Volume2
27/03/23 22:43:55 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
27/03/23 22:43:55 Will run as user: jellyfin and group: media
28/03/23 05:20:39 The main volume is /Volume2
28/03/23 05:20:39 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:20:39 Will run as user: jellyfin and group: media
28/03/23 05:21:24 The main volume is /Volume2
28/03/23 05:21:24 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:21:24 Will run as user: jellyfin and group: media
28/03/23 05:21:48 The main volume is /Volume2
28/03/23 05:21:48 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:21:48 Will run as user: jellyfin and group: media
28/03/23 05:21:52 The main volume is /Volume2
28/03/23 05:21:52 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:21:53 Will run as user: jellyfin and group: media
28/03/23 05:28:48 The main volume is /Volume2
28/03/23 05:28:48 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:28:48 Will run as user: jellyfin and group: media
28/03/23 05:35:44 The main volume is /Volume2
28/03/23 05:35:44 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:35:44 Will run as user: jellyfin and group: media
28/03/23 05:36:21 The main volume is /Volume2
28/03/23 05:36:21 Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:36:21 Will run as user: jellyfin and group: media
