[ ffmpeg ] Record, convert and stream audio and video
About : https://www.ffmpeg.org
Applicable TOS5: 5.1.13 or later versions
App download: https://tmnascommunity.eu/download/ffmpeg
Required packages:
ModBase1 > 1.00.07
With hardware acceleration via vaapi
FFmpeg is the leading multimedia framework, able to decode, encode, transcode, mux, demux, stream, filter and play pretty much anything that humans and machines have created. It supports the most obscure ancient formats up to the cutting edge.
Re: [ ffmpeg ][ 4.3.2.0 ] Record, convert and stream audio and video
added 4.3.2.0
Re: [ ffmpeg ][ 4.4.0.0 ] Record, convert and stream audio and video
up to 4.4.0.0
f404
Post by f404 »
Is possibile to build a package with this: https://github.com/jellyfin/jellyfin-ffmpeg ?
what is different than normal ffmpeg ?
f404
Post by f404 »
This ffmpeg is suited particullary for jellyfin, it makes posssible to use QSV instead of VAAPI, improving transcoding performance.
I'm using the ffmpeg in this post, VAAPI as hardware acceleration and its impossible see for example a 4k movie.
P.S: I got an F1-221 so it has a J3455 cpu
Unfortunately is not possible. In order to enable qsv support, i need to enable the nonfree flag during build which will break the GPL and will make the package unredistributable
f404
Post by f404 »
Oh I see, that unfortunate.
added TOS5 version
Re: [ ffmpeg ] Record, convert and stream audio and video
updated
