[ Jellyfin ] The Free Software Media System
Re: [ Jellyfin ][ 10.7.5.0 ] The Free Software Media System
betuning wrote: 29 Jun 2021, 19:34 Good job
but there is a problem with the identify function, plug-in, it does not return anything.
While with the Docker version these functions work.
But I prefer your version for the Hardware acceleration
i see no issue on my NAS, it returns well the search results
betuning
Post by betuning »
outkastm wrote: 29 Jun 2021, 21:38
I have already reinstalled it twice and each time nothing returns to me it's not because I had installed it via docker
My nas: F5-221 TOS: 4.2.11
Check the log file after you press the identify
betuning
Post by betuning »
outkastm wrote: 29 Jun 2021, 22:19 Check the log file after you press the identify
[2021-06-30 09:29:04.378 +02:00] [ERR] [18] MediaBrowser.Providers.Manager.ProviderManager: Provider "The Open Movie Database" failed to retrieve search results
System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid because of errors in the certificate chain: PartialChain
at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception)
at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm)
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Boolean async, Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)
--- End of inner exception stack trace ---
at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.GetHttpConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.SendAsyncCore(HttpRequestMessage request, HttpCompletionOption completionOption, Boolean async, Boolean emitTelemetryStartStop, CancellationToken cancellationToken)
at MediaBrowser.Providers.Plugins.Omdb.OmdbItemProvider.GetSearchResultsInternal(ItemLookupInfo searchInfo, String type, Boolean isSearch, CancellationToken cancellationToken)
at MediaBrowser.Providers.Manager.ProviderManager.GetSearchResults[TLookupType](IRemoteSearchProvider`1 provider, TLookupType searchInfo, CancellationToken cancellationToken)
at MediaBrowser.Providers.Manager.ProviderManager.GetRemoteSearchResults[TItemType,TLookupType](RemoteSearchQuery`1 searchInfo, BaseItem referenceItem, CancellationToken cancellationToken)
Roberbond
Post by Roberbond »
hi! I have installed the App, and its requeriments the ffmpeg and modbase1.
Modbase 1 is installed and running, but the ffmpeg only show a blank page and it say no access.
When I press the Jellyfin webinterface it tries to connect to http://192.168.0.18:8096 and 8920 and nothing happen.
What can I do?
ffmpeg has nothing to configure on the WebUi so the acceess to that page is not really needed (but will be fixed on the next version)
Regarding Jellyfin, do you still have issues ?
Re: [ Jellyfin ][ 10.7.6.0 ] The Free Software Media System
updated to 10.7.6.0
milaine
Post by milaine »
outkastm wrote: 30 Aug 2021, 06:57 updated to 10.7.6.0
When I restart my nas server (f5-221) it stays stopped and doesn’t want to start.
milaine
Post by milaine »
milaine wrote: 05 Sep 2021, 20:58
To add to this. When I click restart module I get this message for 3 seconds then goes away.
“Restarting Jellyfin: Stopping : No process in pidfile ‘/usr/local/Jellyfin/bin/Jellyfin.pid’ found running; none killed. ok Starting ; ok. ok.”
milaine
Post by milaine »
Nevermind. My issue was I tried to add a plugin manually and guess the app didn’t like that. Solved my problem by deleting it from plugins.
