12/04/23 15:16:58 The main volume is /Volume1
12/04/23 15:16:59 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 15:16:59 Will run as user: jellyfin and group: media
start-stop-daemon --start -c jellyfin -b --exec /Volume1/@apps/Jellyfin/bin/program/jellyfin -- -d /home/momosa/MOD_CONFIG/Jellyfin/data -C /home/momosa/MOD_CONFIG/Jellyfin/cache -c /home/momosa/MOD_CONFIG/Jellyfin/config -l /home/momosa/MOD_CONFIG/Jellyfin/log --ffmpeg /usr/local/ffmpeg/sys/bin/ffmpeg
12/04/23 15:25:11 The main volume is /Volume1
12/04/23 15:25:11 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 15:25:12 Will run as user: jellyfin and group: media
12/04/23 16:50:17 The main volume is /Volume1
12/04/23 16:50:18 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 16:50:18 Will run as user: jellyfin and group: media
13/04/23 09:41:14 The main volume is /Volume1
13/04/23 09:41:16 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
13/04/23 09:41:43 Will run as user: jellyfin and group: media
14/04/23 14:19:03 The main volume is /Volume1
14/04/23 14:19:06 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
14/04/23 14:19:13 Will run as user: jellyfin and group: media
14/04/23 16:35:26 The main volume is /Volume1
14/04/23 16:35:27 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
14/04/23 16:35:27 Will run as user: jellyfin and group: media
16/04/23 12:25:26 Will use /Volume1 to store config files
16/04/23 12:25:26 The main volume is /Volume1
16/04/23 12:25:29 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
16/04/23 12:25:36 Will run as user: jellyfin and group: media
SUCCESS!
16/04/23 14:05:52 Will use /Volume1 to store config files
16/04/23 14:05:53 The main volume is /Volume1
16/04/23 14:05:54 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
16/04/23 14:06:05 Will run as user: jellyfin and group: media
SUCCESS!
17/04/23 09:40:37 Will use /Volume1 to store config files
17/04/23 09:40:38 The main volume is /Volume1
17/04/23 09:40:40 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
17/04/23 09:40:58 Will run as user: jellyfin and group: media
SUCCESS!
