[ Nextcloud ] Self-hosted productivity platform
About :
Applicable models: TerraMaster x.64 series
Applicable TOS6: 6.0.420 or later versions
Applicable TOS7: 7.0.0375 or later versions
App download: https://tmnascommunity.eu/download/nextcloud_okm
Required packages:
apache83
MariaDB_1011 - optional
This native app comes with support for
  • Heic - included
  • Reverse Proxy for external access - using Caddy or NPM
  • ExApps - HaRP docker container
For upgrade, don't skip any major version (32.0.0.0, 33.0.0.0)
TOS6 & TOS7: click on Support & Help from app description inside the App Center
Read the complete installation guide on tmnascommunity.eu
About:
https://nextcloud.com
A safe home for all your data
Access & share your files, calendars, contacts, mail & more from any device, on your terms
Re: [ Nextcloud ][ 21.0.1.0 ] Self-hosted productivity platform that
updated to 21.0.1.0
Re: [ Nextcloud ][ 22.0.0.0 ] Self-hosted productivity platform that
updated to 22.0.0.0 (major version)
Re: [ Nextcloud ][ 22.1.1.0 ] Self-hosted productivity platform
updated to 22.1.1.0
Jesuralem
Post by Jesuralem »
Hi there, how can we upgrade ?
Do i just install the new version over the old one ?
Yes indeed.
After installing the new tpk, when you access the login page it will ask you to perform the update
Re: [ Nextcloud ][ 22.2.0.0 ] Self-hosted productivity platform
up to 22.2.0.0
Re: [ Nextcloud ][ 22.2.2.0 ] Self-hosted productivity platform
up to 22.2.2.0
Re: [ Nextcloud ][ 22.2.3.0 ] Self-hosted productivity platform
up to 22.2.3.0
sanctimon
Post by sanctimon »
I am on F5-221 and these instructions do not work for me. I can get into the control screen immediately after installation, but the module refuses to start and will not allow initial configuration.
