[ModBase1] Common libraries and tools for use by other modules
This module bundles common libraries and tools for use by other modules.
Applicable models: x.64 series, armV8 series
Applicable TOS5: 5.1.13 or later versions
App download: https://tmnascommunity.eu/download/modbase1
Module WebUI for additional settings can be accesses at:
TOS4: http(s)://yournasip:port/modules/ModBase1/www
TOS5: click on Support & Help from app description inside the App Center
Binaries available at /usr/local/ModBase1/sys/bin and this location can be added to PATH using the package WebUI.
Some binaries are using the hashed certificates from TOS and fall back to bundle root certificate pulled from https://curl.se/ca/cacert.pem
The bundle root certificate will be pulled when NAS is rebooted or the ModBase1 is started manually.
And only if the local one available at /mnt/appdata/MOD_CONFIG/SSL_certs/cacert.pem is older than the remote one
Include binaries and more
aspell - 0.60.8
aspell_dict - en
bzip2-1.0.6
byobu - 5.133
coreutils - 8.32
curl-7.74.0
DevIL - 1.8.0
e2fsprogs - 1.46.4
fusermount - 2.9.7
git-2.30.0
glib - 2.52.2
idn2-2.3.0
jasper - 2.0.14
LittleCMS - 2.12
onig - 6.9.6
nano - 5.6.1
openssl - 1.1.1i
pcre-8.40
rar2fs - 1.29.4
screen - 4.8.0
slang - 2.3.2
sqlite - 3290000
tmux - 3.2a
unrar - 6.0
util-linux - 2.29.1
wget-1.21
whiptail (newt) - 0.52.21
Include library
expat-2.0.1
ncurses-6.2
libffi - 3.2.1
libfuse - 2.9.7
libiconv-1.15
libjpeg - 9d
libjpeg-turbo - 2.0.5
libmediainfo-0.7.87
libmng - 1.0.10
libpng - 1.6.22
libpsl-0.21.1
libssh2 - 1.9.0
libtiff - 4.2.0
libzen - 0.4.33
zlib - 1.2.11
Re: [ModBase1][1.00.01] Common libraries and tools for use by other modules
updated to 1.00.01
added: screen, unrar, fusermount, rar2fs
rar2fs
screen
Re: [ModBase1][1.00.02] Common libraries and tools for use by other modules
updated to 1.00.02
Re: [ModBase1][1.00.03] Common libraries and tools for use by other modules
updated to 1.00.03
Re: [ModBase1][1.00.07] Common libraries and tools for use by other modules
updated to 1.00.07
ilian
Post by ilian »
Good job. Thank you!
You fail to mention that this application downloads and installs a complete set of CA certificates. That we know nothing about.
That is not something I wouldn't quietly do for the user's convenience!
A much cleaner solution would have been to fetch the certificates from the curl website: https://curl.se/ca/cacert.pem
Oh... and if you decide to do that, please don't download them 4 times! :)
Btw, I'm not stupid - I'm understand that with the gigabyte of programs you have many, less obvious opportunities to do something evil, if you wanted to! Also Sweden, being one of the oldest EU members, should have a heavy punishment if someone is found guilty of falsifying a digital signature.
Just saying: don't look evil unless you have to! And you don't have to in this case. :)
Cheers,
Ilian
The bundle certificate are required for tools like curl, wget, openssl etc to work properly without forcing to use insecure connections.
https://curl.haxx.se is now pointing to https://curl.se/ca, so the bundle certificate are pulled from https://curl.se/ca
The download command is using --time-cond attribute, the certificate is only pulled when the local one is older than the remote one.
And the download comand is used anyway only when the NAS is rebooted.
But i will remove the download command from the startup script and the binary tools will use the bundle certificate from TOS instead of pulling the latest one.
Re: [ModBase1][1.00.09] Common libraries and tools for use by other modules
Updated to 1.00.09. Also the first post was updated with information how and when the Bundle of CA Root Certificates is pulled
Re: [ModBase1][1.00.10] Common libraries and tools for use by other modules
updated to 1.00.10
added tmux and byobu
Re: [ModBase1][1.00.10.1] Common libraries and tools for use by other modules
updated to 1.00.10.1 to fix a small issue for Sonarr
