[ OracleJRE8 ][ 1.00.02 ] Java SE Runtime Environment
Last version: 1.00.02
Applicable models: TerraMaster x.64 series, TerraMaster arm series
Applicable TOS: 4.1.27 or later versions
Applicable TOS: 5.0.130 or later versions
App download: https://tmnascommunity.eu/download/oraclejre8
Provide java 1.8.0_321
mil_house23
Spain
Re: [ OracleJRE8 ][ 8u271 ] Java SE Runtime Environment
Post by mil_house23 »
Hello!
I already install, but i dont find any documentation, i want to run .jar file?
Can you helpme?
nicolas
This module is used as based for other modules.
Java binary is located at /usr/local/OracleJRE8/bin. So you can run app by
/usr/local/OracleJRE8/bin/java yourapp.jar
If you will create a startup script, you can setup the variable
PATH=/usr/local/OracleJRE8/bin:$PATH
export PATH
JAVA_HOME=/usr/local/OracleJRE8
What app do you want to run ?
Re: [ OracleJRE8 ][ 1.00.01 ] Java SE Runtime Environment
added arm version
onemeshnig
Post by onemeshnig »
Can't install on Russian UI.
added the missing languages.
Download again and install the latest version
onemeshnig
Installed, but I have error.
have you just download the app ?
i fixed something 1 hour a go.
onemeshnig
Now it looks like this
Now is normal. The WebUI just show some info. This app is used as base for other apps that depend on Java
