So how the hell do we get TNAS 5 to run on a windows 11 computer??
TNAS PC for Windows and macOS, TNAS mobile for iOS and Android, and smart TV application and clients.
Tricky
Post by Tricky »
As above, tried all I can think of, and it still won't run, just an icon on the taskbar and that it tried all the compatibilities etc even installed Java as initially I had a Java error come up on installing but no still no joy tried enabling some lesser net framework capabilities, but it still won't run, so what is the problem?
Re: So how the hell do we get TNAS 5 to run on a windows 11 computer??
What language is your computer OS? Language compatibility issues will lead to unsuccessful installation. Will be fixed in the next version.
Tricky
Post by Tricky »
English, and I could install it and run normally on a Windows 10 machine.
deadmonty
Post by deadmonty »
Have you tried compatibility mode? Just a thought.
demetry14
Post by demetry14 »
TNAS PC 5 worked fine for me.
Windows 11 Home 22H2 22621.160
1. Downloaded TNAS PC 5 (5.0.22) from viewtopic.php?f=28&t=3358
2. Extracted the ZIP
3. Double click the EXE
4. Choose more info > allow anyway "because unverified developer"
5. Double click desktop icon
6. Before application will fully launch, a firewall approval prompts, allow firewall rule
7. App opens and immediately finds my TNAS
I suggest making sure the firewall rule is applied and check marked in:
Press: Windows Key + S
Search: Firewall
Choose: Windows Defender Firewall
Choose: Allow an app or feature through the Windows Defender Firewall
Choose: Change settings
Check: TNAS PC and also make sure Private is checked
Click OK and try running TNAS PC again
If that does not work, uninstall, remove the terra master folder from program files or program files (x86), reinstall following the steps above and try again.
Demetry
F2-210
F4-210
Thank you for your sharing. Firewall is the factor stopping the TNAS PC running properly.
Or you can try the latest version just updated today, the version is 5.0.23
Tricky
Post by Tricky »
TNAS PC 5.0.27 seems to work OK on my Windows 11 now but still pretty slow to open, and i still have to log into the TOS 5 machine on the TNAS PC page and not the web interface like the TOS 4 is this by design or does this need more work?
{L_BUTTON_AT}Tricky
May I know what slow to open? TNAS PC? TOS ?
Tricky
Post by Tricky »
{L_BUTTON_AT}Tricky
TMroy wrote: 08 Jul 2022, 10:27 May I know what slow to open? TNAS PC? TOS ?
Yes the TNAS PC is very slow to open, the earlier versions were even slower, I have had Java notifications with the older versions but couldn't find what the problem was, and I have tried with virus protection etc turned off with no difference.
Are you talking about the time it takes to open the TNAS PC first time? How long you need to wait?
