F2-420 bricked
Permissions, domain/LDAP, power, security, notification and more.
Rick
F2-420 bricked
Post by Rick »
after a power failure my F2-420 is no longer accessible
TOS and SSH are not reachable.
port 80 has been changed to Webserver.
Web port TOS is at 200 and is no longer accessible.
TNAS-PC cannot recover the system.
How can I restore the system to factory settings.
already tried all options. boot without HD etc.
Regards
Rick
Re: F2-420 bricked
It seems the system corrupted during the power failure, but not sure if the file system corrupted too or not. please try to reinstall the TOS and if you are prompt to create a new storage pool, then your file system may be corrupted, if your data is important, it is recommended you find a third-party data recovery service.
how to reinstall TOS?
how to repair a corrupted file system?
Rick
Re: F2-420 bricked
Post by Rick »
I can acces all my data and i,m running a backup.
But its impossible to reinstall TOS or get into TOS i cant acces the machine not with putty or with PC-Nas thats the problem.
Howto reinstall TOS
Regards
Rick
Rick
Re: F2-420 bricked
Post by Rick »
If i try to connect with PC-NAS
4. Wait about two minutes, after the network light is on, use TNAS PC to search for your TNAS device;
5. Select the device and click "Login" to the "Initialize" page;
It will open the webppage thats running on port 80 (webserver) and not the "Initialize" page << thats the problem
regards rick
Re: F2-420 bricked
{L_BUTTON_AT}Rick
Before you reboot your TNAS, did you remove all your drives? If you remove all your drives, the TOS will not able to ne loaded, so you can get into the initialization guideline.
Rick
Re: F2-420 bricked
Post by Rick »
Yes i removed all the drives and when i try to login my username and password are not accepted (the master login)
Regards
Rick
Rick
Re: F2-420 bricked
Post by Rick »
Did it with 2 new harddrives and the bootloader started.
New tos installed.
Re: F2-420 bricked
{L_BUTTON_AT}Rick
The file system in your previous drives may be corrupted. You can try to repair them if it contains data which is important to you.
