it seems the update to TOS 4.2.13 messed up with my F2-421's root account... Since I installed it I had a lot of issues with my Plex installation (had to reset the whole thing) and when I tried to connect via SSH as root , I discovered I cannot connect with user admin's password (it gets refused/I get asked for the password again).
Therefore I tried to connect via SSH directly as admin, and it works: however, when I try to use the sudo -i command I get this error:
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
Thanks in advance.
P.S.: also, why my model (F2-421) is no longer listed as product in the products page (https://www.terra-master.com/us/product ... s-nas.html), and I can't even select it in the downloads page (https://support.terra-master.com/download/?lng=en)??? I expect it to be AT LEAST still supported, I bought it less than a year ago!
edit: corrected model, added request for F2-421 update
