F2-210 Reset
russerlaa
F2-210 Reset
Post by russerlaa »
Hi Folks
Apologies if this has been covered before, am a newbie... how do you reset an F2-210?
thanks
Russ
Re: F2-210 Reset
If you can log onto TOS, you can reset it to factory at TOS Control panel - general settings - Update & recovery.
If you cannot log onto TOS, you can reboot your device without any hard drives and click Login and follow the instructions to reset it.
russerlaa
Re: F2-210 Reset
Post by russerlaa »
Apologies for the delayed response.
I have no access to TOS.
Run the windows app, and without the hard drives in, it finds it, so I click "login" where it opens the "initialization" page but just says "no hard rives detected, please install hard drives and try again" and won't let me go past that.
So, I insert the hard drives and then it disappears from the window app.
really appreciate your help, because I can't seem to get it working... it was working, but I changed the TNAS link and it has stopped.
thanks
Russ
Re: F2-210 Reset
Sorry, what's the exact issue now? It seems that you have reinstalled your TOS, so could you log onto TOS now?
Re: F2-210 Reset
You need to replace a hard drive and try again. By the way, what kind of hard drive you inserted into your TNAS?
