TOS Update Notes for F2-210/F4-210 models
Customer Service
Post by TMSupport » 19 Oct 2020, 16:41
Applicable model: F2-210, F4-210
Because of the big difference between TOS4.0 and TOS4.1, your current TOS version may not be updated to the latest version directly.
If you are running below TOS4.1.07, please manually update your TOS one by one as following:
4.1.07 --> 4.1.27 --> 4.1.32
Download link:
TOS4.1.07: https://dl.terra-master.com/cn/TOS_A1.0 ... 7_2883.bz2
TOS4.1.27: http://dl.terra-master.com/cn/TOS_A1.0_ ... 291655.bz2
TOS4.1.32: https://dl.terra-master.com/cn/TOS_A1.0 ... 031214.bz2
It's suggested to backup your data before updating your TOS . The installed apps should be reinstalled after TOS update .
Please go to TOS Control panel - privileges- shared folders- advanced to restore your folders if your files/folders are not visible after TOS update.
Hardfecx
Re: TOS Update Notes for F2-210/F4-210 models
Post by Hardfecx » 19 Oct 2020, 16:54
After Update to 4.1.32 all the services are enabled again.
Customer Service
Post by TMSupport » 19 Oct 2020, 17:27
Which specific services re-enabled after TOS update?
Hardfecx
Post by Hardfecx » 19 Oct 2020, 17:37
all of them, "bonjour", ftp...
sianderson
Post by sianderson » 19 Oct 2020, 19:29
do you really mean 4.1.32 or do you mean 4.1.31? im confused you seem to have just silently released another version without telling anyone and the units do not see an update? so is this an official release or a beta? if a beta whats happening to 4.2?
F2-210
4.2.06-2011031755
scoobyfizz
Post by scoobyfizz » 19 Oct 2020, 21:23
it appears there is a 4.1.32 release which has not been circulated it states on the downloads page -
TOS 4.1.32 Release Notes
This update includes following bug fixes for the previous version:
Fixed the failed reinstallation issue when reinstalled from TOS4.1.31 to TOS4.2.05 Beta.
but it still probably does not fix the problem with settings being set back on still
F2-210
4.1.32-2008031214
sianderson
Post by sianderson » 20 Oct 2020, 01:20
thanks it just seemed a bit of a silent one that the only way i would have known is by reading this no descript update post where as normally there is a post about a new version number
F2-210
4.2.06-2011031755
michaels2408
Post by michaels2408 » 20 Oct 2020, 08:21
4.1.32 - NFS still not functioning correctly. Looses connection. RPC stops working and has to be restarted. {having to use samba for linux drive access. :roll:
SNMP works, but is not configurable via GUI snmp setup screen. Set to public access, china as location. Very poor scripting.
When are these issues going to be corrected? They are not functioning in the 4.2.x beta versions either.
virix
Post by virix » 25 Oct 2020, 19:13
hello to all, i'm a beginner on my F2-210 model, how can i updated the apps to the new SW updated TOS version ? seems that from the update i can't use anymore most of them.
Customer Service
Post by TMSupport » 25 Oct 2020, 22:28
Can you tell us what "SW" means?
