F2-220 TOS update
Mattmoran11
F2-220 TOS update
Post by Mattmoran11 » 14 Oct 2020, 18:01
Recommended update now my tos app won't run tried the reboot where u start up tnas with out hard drive then reinstall hard drive it then starts to install then get 55 percent and says failed try again
Customer Service
Re: F2-220 TOS update
Post by TMroy » 14 Oct 2020, 21:54
Your TOS may be very out of date, you are not able to install the latest version. You have to update your TOS stey by step.
The correct steps to update your TOS: 4.0.09 --> 4.1.03 --> 4.1.15 --> 4.1.30
So now, you need to download the 4.0.09 installation package from the download center, and update your OS as I mentioned above.
download.terra-master.com
Mattmoran11
Post by Mattmoran11 » 15 Oct 2020, 05:31
Very good sir thank you :D
