TOS 4.2.05 beta is released for testing
Customer Service
Post by TMSupport » 27 Sep 2020, 12:04
TOS4.2.05 Release Notes
This update includes following bug fixes for the previous version:
1. Added files task feature;
2. Removed the recycle bin from TOS desktop;
3. Added independent recycle bin for shared folders;
4. Optimized the Token expired issue;
5. Fixed the issue that files could not be deleted at TOS webpage;
6. Fixed the limited capacity issue of volume, users could customize the capacity of volumes;
Important Note
Beta version is an early version of a program or application that contains most of the major features, but is not yet complete, there may still be bugs. This version is released only to a select group of people, or to the general public, for testing and feedback. We do not recommend that you use the Beta version in your work environment.
Only TOS4.2.04 could be upgraded to TOS4.2.05 directly, other versions could not be upgraded to this one.
File link for X86 models:
http://dl.terra-master.com/cn/TOS_Beta2 ... 181846.ins
http://dl.terra-master.com/cn/TOS_Beta2 ... 181846.bz2
UncleJohnsBand
Re: TOS 4.2.05 beta is released for testing
Post by UncleJohnsBand » 28 Sep 2020, 01:24
Loaded 4.2.05 patch as I had already done the complete reinstall with 4.2.04.
No issues running patch.
One thing I did discover with 4.2.04 was that OneDrive and SnapShot were still registered as installed.....but didn't work. I had to uninstall and re-install to get them functional.
I'll report back if any issues surface while using.
yorch
Post by yorch » 28 Sep 2020, 21:28
Does NOT work FTP, SFTP, neither in your network or from outside.
The mobile APK still cannot connect to the nas, it keeps saying "wrong username and / or password".
I begin to think that both failures are related to each other by some authentication failure.
Waiting, to check if the hibernation of hard drives works.
For now, I have not found any more bugs.
F2-221
Customer Service
Post by TMSupport » 29 Sep 2020, 10:59
yorch wrote:
28 Sep 2020, 21:28
There is a beta mobile version adapted to TOS 4.2.05.beta
viewtopic.php?f=6&t=868
gattolino
Post by gattolino » 01 Oct 2020, 20:12
samba share seem not working at all. The process is up but i'm unable to connect from mac or windows
Customer Service
Post by TMroy » 01 Oct 2020, 22:50
May I have your model please?
gattolino
Post by gattolino » 01 Oct 2020, 23:53
F2-220
loopylion
Post by loopylion » 03 Oct 2020, 19:23
I'm using this beta on an F5-221 and I cannot import and apply SSL certificates. I can locate the key and the crt file in the Security control panel, but I click apply and nothing happens.
sports_wook
Post by sports_wook » 15 Oct 2020, 04:10
I'm using this beta on an F2-220 and the Web Server option in the Control Panel is missing from the Network Services menu...is this a known bug? Is there anyway to restore it?
sports_wook
Post by sports_wook » 15 Oct 2020, 23:26
Working screenshot:
