TOS 4.1.31 is released for update
Hardfecx
Re: TOS 4.1.31 is released for update
Post by Hardfecx » 09 Oct 2020, 02:26
Well, for my F4-210 the Update runned automaticly and nothing was enabled wich was disabled before the update.
yorch
Post by yorch » 09 Oct 2020, 03:11
Hardfecx wrote:
09 Oct 2020, 02:26
does sharing files with password work?
Does disk hibernation work?
does ftp and sftp work?
Greetings, if you could confirm ...
Greetings and thank you very much
F2-221
Zan
Post by Zan » 09 Oct 2020, 05:42
Just updated my f2 210 a few days ago and every time i try to log via the web interface it lags and i can no longer access my my server
Hardfecx
Post by Hardfecx » 09 Oct 2020, 13:32
yorch wrote:
09 Oct 2020, 03:11
Hardfecx wrote:
09 Oct 2020, 02:26
Sharing works, hibernation too. But FTP and Sftp i didn't try
yorch
Post by yorch » 09 Oct 2020, 20:24
Hardfecx wrote:
09 Oct 2020, 13:32
yorch wrote:
09 Oct 2020, 03:11
Hardfecx wrote:
09 Oct 2020, 02:26
thank you very much ;)
F2-221
Customer Service
Post by TMroy » 09 Oct 2020, 22:48
Zan wrote:
09 Oct 2020, 05:42
what did you mean? Would you provide more specific? screenshot?
brianx87
Post by brianx87 » 10 Oct 2020, 05:39
Normally the update software doesn't allow you to open updates for different models, I tried to install this on my F220 without realizing it was for ARM models only, the updater attempted to install it any way, it froze mid unpacking.
DJ_Smelly
Post by DJ_Smelly » 12 Oct 2020, 14:13
I have a new F4-210 that I installed 4.1.30 (without Patch 1.03) and then updated to 4.1.31 but it did not fix my issues. I have 4 HDDs (1TB, 1TB, 500GB, 500GB) in a RAID1/RAID1 configuration. Scheduled shutdown between 0100hrs and 0800hrs each day (this is working). Hibernate is set at 30 minutes (this seems to work). Remote Access is enabled. I have installed ClamAV, OneDrive and DLNA.
My issues are:
* The unit still randomly loses connection. All lights are solid green on the front of the unit and the HDDs stay in hibernated state and don’t spin up. Cannot connect via mapped folders or from Chrome in multiple Windows 10 machines on both wired and wifi connections. TNAS Mobile app for iOS says “LAN online” but when I try to login it says “Login timout!” and “Network connection error. Please try again later”. Restarting the NAS fixes this issue temporarily but then it drops out again, sometimes after about an hour and sometimes a couple of days. There isn’t a consistent elapsed time period. This seems to have been worse since I enabled Remote Access a couple of days ago.
* In Windows 10, the NAS “\\SERVER” randomly disappears from my Network list and any folder mappings using “\\SERVER” do not work. But it works if I change it to the IP address “\\192.168.0.x” instead of “\\SERVER”. After restarting the NAS the “\\SERVER” reappears but then disappears randomly again.
* The power button on the front of unit does not work. Have tried short press, 3 second press and 10 second press but the unit stays powered on. I have to pull the plug from rear to shutdown or restart.
* FTP, Telnet, etc was enabled after the update to 4.1.31 when they were disabled before.
Hardfecx
Post by Hardfecx » 12 Oct 2020, 16:02
DJ_Smelly wrote:
12 Oct 2020, 14:13
My issues are:
Have a look in your "Windows features" if "SMB 1.0/CIFS" are enabled.
sianderson
Post by sianderson » 12 Oct 2020, 17:33
could this be your router playing up, as no doubt that would be acting as a dns server? and its losing its memory of what name translates to what IP? so the act of rebooting the nas will update it to say im here?
my question would be when you can no longer access the name, can you ping the name and does it translate it to an IP address or not (regardless of whether it gets a successful ping)
F2-210
4.2.15
