TOS patch 1.03 released for ARM models
Customer Service
Post by TMSupport » 23 Sep 2020, 11:26
Release Notes:
Fixed the issue of F2-210/F4-210 randomly loses connection or does not power off by pressing the power button.
Applicable: TOS versions from 4.1.21 to 4.1.30;
How to update:
1. Download the package to your computer: http://dl.terra-master.com/cn/TOS_PATCH_ARM_1.03.bz2
2. Power on the TNAS and log in the WEB GUI.
3. Go to TOS Control Panel – General Settings – Update & Recovery – Manual upgrade, browse and select the downloaded package and click “Apply” to upgrade.
4. The TNAS will automatically restart when the OS upgrade is completed.
sianderson
Re: TOS patch 1.03 released for ARM models
Post by sianderson » 23 Sep 2020, 17:21
thanks, i was renaming a few files on my F2-210 via a mapped network drive i then got an error message saying i needed administrator privileges although it had just done quite a few already under the same situation
it was allowing me to delete other files in the same folder, i then went to clear out the recycle folder to free up space and the nas drive then just suddenly dropped off the network (multiple computers lost connection to the nas drive and no response to the web interface) so pulled the plug and plugged it back in and it booted up again and allowed me to rename those files without changing anything on the PC
then saw this update so i have applied it, fingers crossed this may resolve that issue
F2-210
4.2.06-2011031755
Southland
Post by Southland » 24 Sep 2020, 08:24
Is this patch OK to install on top of 4.1.30?
sianderson
Post by sianderson » 24 Sep 2020, 16:50
if it helps thats exactly what i have done and mines running perfectly after
the dashboard shows my version as 4.1.30-2008031214-P1.03
the last bit i understand to show that its patch 1.03 thats installed
F2-210
4.2.06-2011031755
macmpi
Post by macmpi » 24 Sep 2020, 17:23
TMSupport wrote:
23 Sep 2020, 11:26
Release Noets:
Will you please make clear statement in Release notes about applicable TOS version(s) to apply this new Patch onto?
Maintenance for production units & services can not be based on guesses.
Thought it was acknowledged and understood as per this.
TMroy wrote:
18 Aug 2020, 23:32
Sure and thank you!
Thanks for consideration.
TerraMaster F2-210 under TOS 4.2.06, RAID1, Btrfs, serving Mac, Linux & Windows clients
Customer Service
Post by TMroy » 24 Sep 2020, 18:42
The patch 1.03 is applicable for TOS 4.1.21 or later versions.
macmpi
Post by macmpi » 25 Sep 2020, 15:58
TMroy wrote:
24 Sep 2020, 18:42
Thanks for this.
Now, this patch will probably be integrated in next TOS release, right?
Then, if a reader reads this thread in a few months from now, he/she should know this update is not applicable to latest at that time...
Therefore, wouldn't it make sense to be more conservative in term of future release and say: applicable for TOS 4.1.21 up to 4.1.30?
Thanks to include such kind of information in any future release, this helps a lot.
Customer Service
Post by TMroy » 25 Sep 2020, 22:20
macmpi wrote:
25 Sep 2020, 15:58
Appreciate your advice. I already revised the release notes.
macmpi
Post by macmpi » 25 Sep 2020, 22:36
Thanks.
Now you may want to do similar for older TOS Patches like patch 1.02, as it is still available on the Forum (or note it is depreciated).
Plus, if 1.02 & 1.03 are both valid for some same releases, do they both need to be applied? in which order? Or is the last one including the first one?...
Customer Service
Post by TMroy » 25 Sep 2020, 22:47
haha, you are so great to help! it is done. Thank you!
