TOS 4.2.04 beta is released for testing
gattolino
Re: TOS 4.2.04 beta is released for testing
Post by gattolino » 07 Sep 2020, 23:17
seem there's also a problem with plex that try to use the avahi uid and gid
yorch
Post by yorch » 08 Sep 2020, 03:34
yorch wrote:
07 Sep 2020, 23:15
SMB does not work. :(
When you try to connect the network drive, you enter the credentials, it tells you that the folder is assigned with another name, another user and another password.
SMB now if it works correctly. I don't know why, it gave me that failure. Reboot, and I retyped the password in the admin user menu, and it seems the problem has been fixed.
F2-221
yorch
Post by yorch » 08 Sep 2020, 03:45
gattolino wrote:
07 Sep 2020, 23:17
My plex works fine for me. I have only tested it within my own network, but it works fine. I need to try it out of my network, but I have not noticed any problem.
F2-221
tutuzik
Post by tutuzik » 09 Sep 2020, 00:39
In the Russian version, the tabs equipment power do not work
UncleJohnsBand
Post by UncleJohnsBand » 24 Sep 2020, 10:37
Loaded this Beta. No issues with getting it installed following the instructions to do a complete reset....which seems a little excessive.
I report back if I find any issues in my usage.
Ryzen
Post by Ryzen » 01 Oct 2020, 20:07
Do you know when this firmware will be offered in final version ?
F2-210
4.2.06
UncleJohnsBand
Post by UncleJohnsBand » 01 Oct 2020, 20:15
There is a 4.2.05 Beta now avaialble....
splaquet
Post by splaquet » 15 Oct 2020, 22:20
I've had to do a reinstall of the complete package before. When I had previously taken that step, my settings and customizations had not actually reset.
As it states to push a 'factory restore' in the steps, I wanted to confirm/double-check on settings and drive content. Will following the steps for 4.2.04 actually wipe the entire system clean, and I'll lose all of my settings/NAS storage content? ...or will everything be preserved?
Customer Service
Post by TMroy » 15 Oct 2020, 23:53
If you re-install a fresh new system instead of update, all your configuration will be erased. So it is recommanded you backup your system configuration before you reset to factory defualt and re-install the all new TOS.
splaquet
Post by splaquet » 02 Nov 2020, 03:08
just to confirm... Only our settings/configurations will be lost, yes? ...not that all of the harddrive data will also be lost/erased during a complete install?
