TOS 4.2.04 beta is released for testing
Customer Service
Post by TMSupport » 04 Sep 2020, 12:13
TOS 4.2.04 beta Release Notes
Applicable models:
X.86: F2-220, F2-221, F2-420, F2-421, F4-220, F4-221, F4-420, F4-421, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422.
This update includes following bug fixes for the previous version:
1. Added WOL feature;
2. Added Report Issues module under Technical Support;
3. Optimized the hibernation feature of HDDs;
4. Fixed system vulnerabilities;
5. Fixed the scheduled backup failure of Rsync;
6. Fixed the issue that WiFi should be reconnected after TNAS is rebooted;
7. Added a system language –Russian;
8. Added Advanced setting for users;
9. Added quota setting for shared folders under Btrfs file system;
10. Added customized time server;
11. Optimized the calculation method of memory usage;
12. Added shutdown delay feature;
13. Optimized the issue of user account deactivation and activation;
14. Optimized the problem that Windows cannot recognize the exfat USB drive formatted by TNAS.
ARM: F2-210, F4-210
9. Added customized time server;
10. Optimized the calculation method of memory usage;
11. Added shutdown delay feature;
12. Optimized the issue of user account deactivation and activation;
13. Optimized the issue that no beeps of buzzer when TNAS is powered off.
Important Notice
Beta version is an early version of a program or application that contains most of the major features, but is not yet complete, there may still be bugs. This version is released only to a select group of people, or to the general public, for testing and feedback. We do not recommend that you use the Beta version in your work environment.
You need to clean your browser cache after installing;
How to install TOS beta?
1. Download the installation package:
For X86: https://download2.terra-master.com/TOS_ ... 281837.ins
For ARM: https://download2.terra-master.com/TOS_ ... 281842.ins
2. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Restore to factory default”;
3. Click "Apply" and follow the instruction;
4. choose manual download and install TOS ;
5. follow the instructions to complete
Issue report:
If you encounter issue during testing, please report to TerraMaster official forum “TOS update”.
macmpi
Re: TOS 4.2.04 beta is released for testing
Post by macmpi » 04 Sep 2020, 17:00
TMSupport wrote:
04 Sep 2020, 12:13
X.86: 9. Added quota setting for shared folders under Btrfs file system;
Will that come soon on ARM too?
That would really help, in particular to control TimeMachine storage expansion.
Thanks.
TerraMaster F2-210 under TOS 4.1.30, RAID1, Btrfs, serving Mac, Linux & Windows clients
Tricky
Post by Tricky » 04 Sep 2020, 17:51
My friend who is running the last beta TOS update on his F5-221 Downloaded the file and tried to update but gets an error message when trying to select the update.
Customer Service
Post by TMroy » 04 Sep 2020, 17:53
Unfortunately, he did not read the update instruction. This is an installation package, not an update package, please follow the instruction.
To contact our tech team or want a remote session, please email to support(at)terra-master.com
Customer Service
Post by TMroy » 04 Sep 2020, 18:03
macmpi wrote:
04 Sep 2020, 17:00
Yes, the ARM version already came together with the x.86, I guess this released note is too long to read.
sports_wook
Post by sports_wook » 04 Sep 2020, 23:20
For those who have installed this - how stable is the experience? Do you regret updating to the newer version? I'm tempted to try it out but don't want to lose functionality, jeopardize my data, or encounter a ton of bugs.
Online
sianderson
Post by sianderson » 05 Sep 2020, 00:55
as 4.1.30 is stable for me i shall just wait and see what reports come out, i assume this beta includes everything that was in 4.1.30 and more as the original 4.2 beta was out before this?
F2-210
4.1.32-2008031214
tutuzik
Post by tutuzik » 05 Sep 2020, 03:57
i don't want to reinstall i want to update is there an update file ??
yorch
Post by yorch » 07 Sep 2020, 22:53
For now everything seems correct, except for three small errors, which I will post your captures later.
Now, finally, it seems that sharing with password works, restarting the device, all the options remain intact.
Little by little things are going well.
1. When you enter the storage block, and the system begins to test the hard drives, it stays that way for life, you constantly hear the hard drives working.
2. In power, the first option to mark is empty. at least in Spanish.
3. In the section ups, the model, time remaining, comes out on top with other characters.
F2-221
yorch
Post by yorch » 07 Sep 2020, 23:15
SMB does not work. :(
When you try to connect the network drive, you enter the credentials, it tells you that the folder is assigned with another name, another user and another password.
F2-221
