TOS 4.1.30 is released for update
Customer Service
Post by TMSupport » 10 Aug 2020, 14:56
TOS 4.1.30 Release Notes
For models: F2-210/F4-210
1. Optimized the calculation method of memory usage;
2. Updated the Time server;
3. Optimized the GUI of Rsync backup;
4. Added the inspection and repair feature to HDDs and RAID at booting up;
5. Added RTD 8812BU wireless network card driver.
TOS 4.1.30 Release Notes for models:
F2-220/F2-420/F4-220/F4-420/F5-420
F2-221/F2-421/F4-221/F5-221/F5-421
F4-422/F5-422
1. Updated the Time server;
2. Optimized the GUI of Rsync backup;
3. Added the inspection and repair feature to HDDs and RAID at booting up;
4. Added the automatically transcoding feature of videos at webpage.
How to install TOS update?
1. Download the update package:
ARM: http://dl.terra-master.com/cn/TOS_A1.0_ ... 061204.bz2
X.86: http://dl.terra-master.com/cn/TOS_S2.0_ ... 061157.bz2
2. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Manual Update”;
3. Click "Browse" to select the update package;
4. Click "Apply";
Issue report:
If you encounter issue during using, please report to TerraMaster official forum “TOS update”.
Hardfecx
Re: TOS 4.1.30 is released for update
Post by Hardfecx » 10 Aug 2020, 16:25
I can't do this update because of an higher version:
Customer Service
Post by TMroy » 10 Aug 2020, 16:30
you are running a 4.2 beta version, which cannot update directly with a 4.1 update package. If you would like to give up the 4.2 beta, and install latest 4.1, you have to reinstall your tos with a 4.1.30 ins package.
viewtopic.php?f=75&t=423
To contact our tech team or want a remote session, please email to support(at)terra-master.com
Tricky
Post by Tricky » 10 Aug 2020, 16:33
That's because the beta update is a higher version i have a friend running it on a F5-221 and so far its been pretty stable but i think there maybe some function glitches ....I'll ask.
Tricky
Post by Tricky » 10 Aug 2020, 16:38
That's odd is there a problem with the server that the update is stored on as it only 110 MB yet my download is reporting 30 minutes to download?
scoobyfizz
Post by scoobyfizz » 10 Aug 2020, 16:49
Tricky wrote:
10 Aug 2020, 16:38
Demand/bandwidth I suspect.. been downloading for some time now and it's only done 50mb and says 20 mins left...
F2-210
4.1.32-2008031214
Tricky
Post by Tricky » 10 Aug 2020, 16:51
scoobyfizz wrote:
10 Aug 2020, 16:49
Tricky wrote:
10 Aug 2020, 16:38
Didn't think there would be that much call for it the ARM version downloads in seconds.
scoobyfizz
Post by scoobyfizz » 10 Aug 2020, 16:59
I'm downloading the ARM version...
F2-210
4.1.32-2008031214
scoobyfizz
Post by scoobyfizz » 10 Aug 2020, 17:04
Re-downloaded in seconds :-)
F2-210
4.1.32-2008031214
scoobyfizz
Post by scoobyfizz » 10 Aug 2020, 17:20
Initial findings -
1) AFP re-enabled after updated.
2) FTP re-enabled after updated.
3) Work group in SMB settings set back to workgroup after updated.
4) Telnet and SSH re-enabled after updated.
The above settings were reset and they seem to be retained after reboot. However the Rsync settings still randomly reset the user id and loose the directory after restart.
Memory a lot lower after update. See how this goes with the backup from my main NAS overnight.
F2-210
F2-210
4.1.32-2008031214
