TOS 4.1.29 is released for update
Customer Service
Post by TMSupport » 22 Jul 2020, 14:41
TOS 4.1.29 Release Notes
Applicable models:
ARM:
F2-210/F4-210
X.86:
F2-220/F2-420/F4-220/F4-420/F5-420
F2-221/F2-421/F4-221/F5-221/F5-421
F4-422/F5-422
This update includes following bug fixes for the previous version.
1. Fixed the issue of disabled UPnP/Telnet/Bonjour service would be enabled automatically after TNAS reboot;
2. Fixed the issue of the 10th volume could not be seen and used;
3. Fixed the issue of failed downloading at TOS File Manager.
How to install TOS update?
1. Download the update package:
ARM: http://dl.terra-master.com/cn/TOS_A1.0_ ... 201022.bz2
X.86: http://dl.terra-master.com/cn/TOS_S2.0_ ... 171904.bz2
2. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Manual Update”;
3. Click "Browse" to select the update package;
4. Click "Apply";
Issue report:
If you encounter issue during using, please report to TerraMaster official forum “TOS update”.
Tricky
Re: TOS 4.1.29 is released for update
Post by Tricky » 22 Jul 2020, 19:13
Is this a sorted version of the 4.2.01 beta?
Customer Service
Post by TMroy » 23 Jul 2020, 23:26
4.1.29 is a new update from 4.1.28.
Tricky
Post by Tricky » 24 Jul 2020, 01:01
TMroy wrote:
23 Jul 2020, 23:26
Yes i can see that...i was just asking what relation was the new update to the 4.2.1 beta version?
scoobyfizz
Post by scoobyfizz » 24 Jul 2020, 14:40
AFP and FTP were also re-enabled after reboot after this update, but only after the update.
However, now when restarted the SMB/CIFS file service settings are disabled and also the Rsync user id field is being defaulted to rsync after reboot.
F2-210
F2-210
4.2.08
Jonas Pi
Post by Jonas Pi » 24 Jul 2020, 17:02
For me everything worked fine so far.
- NFS & SMB are still enabled after reboot
- FTP & Telnet are still disabled after reboot.
I was restarting about 3 times.
Thanks for the fix,
if it's not going to work anymore i'll let you know.
Jonas
F4-210
Customer Service
Post by TMroy » 24 Jul 2020, 23:43
Tricky wrote:
24 Jul 2020, 01:01
TMroy wrote:
23 Jul 2020, 23:26
There are many features and changes implemented in 4.2, but not in 4.1.28 or 29.
Tricky
Post by Tricky » 29 Jul 2020, 00:32
The restart function odes not work when power goes out happened twice now.
Tricky
Post by Tricky » 29 Jul 2020, 17:36
Re the last comment i thought it was just due to power outs but for the last two nights i have found the F5-221 on the 4.1.29 update has not been visible on the network or via the TNAS screen and requires a restart to get it visible again.
On a side note a friend with the same TNAS has been running the 4.2.02 beta is running with less problems than this update and it actually turns the unit back on after a power out.
Also i am still getting regular like 6 times a day notifications that the CPU has exceeded 90%!
brianx87
Post by brianx87 » 31 Jul 2020, 01:40
I'm suffering from high CPU spikes since updaing to 4.1.28 and the same on 4.1.29 and device is failing to follow the custom power schedule
https://imgur.com/a/Y8rmUfY
