TOS 5.1.79 (X86) is Released for Update
IMPORTANT NOTICE
Attention: TOS 5.1 System Update
If your initial system was TOS 4.x and your system partition is 2GB, please refrain from updating to the new TOS 5.1 version. The updated version demands more storage space, and this requirement may not be met by your current system.
How to Check Your System Partition Size:
Navigate to "TOS > Control panel > System Info > Overview" and inspect the available space under the "/" section.
In the event that your TNAS does not meet the storage conditions but you wish to proceed with TOS 5.1.79, please follow the guidelines provided here: viewtopic.php?f=28&t=4912
Release Notes
Applicable Models: F2-220, F2-420, F4-220, F4-420, F5-420, F2-221, F2-421, F2-422, F4-221, F4-421, F4-422, F4-223, F5-221, F5-225, F5-421, F5-422, F8-421, F8-422, F2-223, F4-223, F2-423, F4-423, T6-423, T9-423, T12-423, T9-450
What's New:
  1. Added RAR file format decompression functionality.
  2. Introduced the ability to manage desktop notifications for Telnet/SSH.
  3. Compatibility update for Terra Photos version 1.2.85.
  4. Compatibility update for TNAS Mobile version 3.2.25.
Bugs Fixed:
  1. Resolved issues in Security Isolation Mode.
  2. Fixed problems related to hard drives.
  3. Addressed issues in the HyperLock-WORM file system.
  4. Resolved user-related issues.
  5. Fixed issues within the File Manager.
  6. Upgraded the Nginx version to 1.21.0.
  7. Updated the SSL certificate for TNAS.online.
Important Notes:
  • Users of TOS 5.1.37 should be aware that encrypted folders created in this version may face decryption issues in subsequent updates. It is recommended to back up data in the encrypted shared folder and delete it before proceeding with the update. This applies only to encrypted shared folders created in TOS 5.1.37.
  • The kernel of TOS 5.1 has been updated to 5.15. As a result, Intel Celeron J1800/J1900 GPU drivers are no longer supported in these models. If you rely on GPU hardware video acceleration and own any of the affected models, avoid updating to TOS 5.1. These models include F2-220, F2-420, F4-220, F4-420, and F5-420.
  • While the system update typically doesn't affect your hard drive data, it is strongly recommended to back up your data to ensure its safety before proceeding with the update.
How to Update Your TOS:
Manual Update:
  1. Download the update package here (md5: abc1d34a13965c7d4033fcd99ee0f030).
  2. Go to TOS > Control Panel > General Settings > System.
  3. In the "Manual Update" section, upload the update package.
  4. Click "Apply."
  5. After the system update is complete, refresh your web browser.
  6. Note that your TNAS's IP address may change after the update; if you can't connect with the previous IP, search for the new IP using the TNAC PC client.
TNAS PC:
After updating to TOS 5.1, ensure that your current TNAS PC is updated to version 5.0.33 or a later version. This step is essential for searching your TNAS device.
Download TNAS PC 5.0.35 for Windows OS
Download TNAS PC 5.0.41 for macOS
It is recommended to uninstall the previous version before installing this version of TNAS PC.
Issue Report:
If you encounter any issues during use, please report them on the TerraMaster official forum, or email your issue description and screenshots to pm(at)terra-master.com.
UncleJohnsBand
Re: TOS 5.1.79 (X86) is Released for Update
Post by UncleJohnsBand »
Loaded without issue and it is running as it should.
DERIKKU
Post by DERIKKU »
Update from 5.1.67. after 20 minutes no response. no ping no weggui no ssl. restart more than 3 times. nothing
F5-221
TNAS 10TB
RAM 10GB
{L_BUTTON_AT}DERIKKU
Is the network light normal? Have you installed any other third-party applications? You can try logging in to the router to check or restart the router. If you have a monitor, you can use HDMI to connect to TNAS and then turn it on again to check.
DERIKKU wrote: ↑18 Oct 2023, 14:50 Update from 5.1.67. after 20 minutes no response. no ping no weggui no ssl. restart more than 3 times. nothing
I just checked all your posts starting from 2023 April 23 when you firstly updated to 5.1.33, you have issues with almost every update, but this does not seem happen to most of users, so please check:
1. what size of the system partition you have? because you installed back to TOS 4 once, I suspect you have only 2GB system partition;
2. if your all drives are healthy?
3. if your TNAS hardware failure?
ostaporomo
Finland
Post by ostaporomo »
F2-223. Updated without problems from TOS 5.1.67 to TOS 5.1.79. Let's see how everything will work in the future. Thank you!
TNAS F2-223
TOS 5.1.79-00214
2x RAM Samsung 16GB DDR4 2133 MHZ
2x HDD Segate IronWolf ST4000VN008 4TB [RAID1]
DAS D4-300
2x HDD Seagate SkyHawk ST3000VX010  [RAID1]
2x HDD Toshiba DT01 DT01ACA300-3TB
ostaporomo
Finland
System time display does not work. Switching to manual, synchronization with the server, synchronization with the browser leads to the appearance of the time display for a fraction of a second. After this, do the NaN NaN NaN appear again.
TNAS F2-223
TOS 5.1.79-00214
DAS D4-300
ostaporomo
Finland
pic
TNAS F2-223
TOS 5.1.79-00214
DAS D4-300
brunix86
Italy
Post by brunix86 »
{L_BUTTON_AT}TMRyan
Hi, I have the same time issue of the user "ostaporomo". My TOS was 5.1.67 and was fresh installed a month ago in a new TNAS F4-423 device. As you can see, the time isn't visible:
The time has null value everywhere, also in Control Panel > Region & Language > Time settings. I noticed that after update, the "Time zone" field is empty. If also fill the field, the issue still occurs. Could you kindly check and solve the issue? Thanks and Best Regards!
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.1536 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
TMLyy
Post by TMLyy »
Please change the date and time format to see if it displays properly.
