4.1.24 install issue
macmpi
Post by macmpi »
I made a 4.1.24 full reinstall (from 4.1.18) on F2-210 (btrfs), keeping all previous data.
Download & install install got stuck at 49% for quite a while.
With manual download, it worked fine.
After install, File Manager would only see public and appdata folders.
Share folders still exist in /mnt with all content, but they can't be seen in File Manager: quite strange.
How can we have File Manager display all files and share as previously?
Thanks.
TerraMaster F2-210 under TOS 4.2.43, RAID1, Btrfs, serving Mac, Linux & Windows clients
Re: 4.1.24 install issue
After the TOS reinstallation, to ensure you can see the data in your hard drives, please check the following:
1. Please ensure the admin user has the R/W permission to the shared folders.
Please go to TOS Control Panel – Privileges – User – select the user and Edit – Permission
2. Please ensure the shared folder’s R/W permission is authorized to the user:
Please go to TOS Control Panel – Privileges – Shared Folder – select the shared folder and Edit – please check in User permission and Group permission accordingly.
3. If you are still unable to see the data, please go to TOS Control Panel – Privileges – Shared Folder – Advanced – Restore to
macmpi
Post by macmpi »
Thanks.
Return to “Initialization”
