TOS 5.1.33 (X86) is Released for Update
WARNING!
Since the new version of TOS 5.1 system requires more storage space, if your initial system was TOS 4.x and system partition is 2GB, please do not update to this version.
To check the free space of your system partition,
Go to "TOS > Control panel > System Info > Overview", and check free space from the item of "/" .
Release Notes
Applicable models: F2-220, F2-420, F4-220, F4-420, F5-420, F2-221, F2-421, F2-422, F4-221, F4-421, F4-422, F4-223,F5-221, F5-225, F5-421, F5-422, F8-421, F8-422, F2-223, F4-223, F2-423, F4-423, T6-423, T9-423, T12-423,T9-450;
This update includes the following bug fixes and optimization for the previous version:
1. Optimized the speed of SMB under 10GbE network environment.
2. Fixed an issue that 423/223 series cannot use hardware video acceleration.
3. Modified the download path of the update package.
4. Fixed an issue that the array in the external hard disk box could not be repaired.
Important Notes
  • The kernel of TOS 5.1 has been updated to 5.15. Since the Linux kernel has removed the Intel Celeron J1800/J1900 GPU drivers from 5.15, the models of this platform no longer support GPU hardware video acceleration. If you are a user of this series of models and need to use GPU hardware video acceleration, do not update TOS 5.1! Models involved: F2-220/F2-420/F4-220/F4-420/F5-420
  • Under normal circumstances, the system update will not affect the data in your hard drives, but for your data safety, it is strongly recommended that you back up your data before the update!
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.1.33 (md5:6cc729a16a67010429d2374e0abc7e4c)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
TNAS PC:
After updating to TOS 5.1.33, you need to update your current TNAS PC to 5.0.33 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.33 for Windows OS
2. TNAS PC 5.0.33 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to pm(at)terra-master.com
franco72
Re: TOS 5.1.33 (X86) is Released for update
Post by franco72 »
How do you test updates before release???!!!
I got a white screen when upgrading from 5.1.31 to 5.1.33. Rebooting doesn't help. De-energizing does not help. The system is installed on SSD M2. I even extracted all the HDD and tried to start it, but still - a white screen!!!
How can I install the previous version now if the system doesn't boot??? Disassemble the NAS and remove the SSD M2?
What to do???
gaz2k1uk
Post by gaz2k1uk »
Managed to update from 5.1.31 to 5.1.33 on 422 without issue, just need to test for a few days.
Setup:
System: F2-422
OS: TOS 6.0.535
HD: x2 IronWolf 6TB (RAID 0)
Notes: 8GB System Partition!
Backup:
USB COPY: Seagate 8GB External Expansion HDD
franco72 wrote: ↑19 Apr 2023, 22:26 How do you test updates before release???!!!
What to do???
Such an issue does not happen in our lab, this should be a special case. do you mind having a remote session with our tech team to check the issue?
powerQ
Singapore
Post by powerQ »
Just updated my two devices without issue.
franco72
Post by franco72 »
TMroy wrote: ↑19 Apr 2023, 23:33
Yes. How can I contact you? F4-423
powerQ
Singapore
Post by powerQ »
What to do???
You may need to wait for a while before the system respond. sometimes the system responds slowly or is checking this file system.
gaz2k1uk
Post by gaz2k1uk »
My adaptive load balancing has dropped to speeds of:
Lan 1 - 100Mbps
Lan 2 - 1000Mbps
Bandwith 1100Mbps
This was previous 1000/1000. I have tried to delete and setup again but does not change.
All connected to Gigabit connections
Setup:
System: F2-422
OS: TOS 6.0.535
Backup:
franco72
Post by franco72 »
I checked the source code of the white page in the browser and see this:
<body class="overBody"><noscript><strong>We're sorry but TOS5 doesn't work properly without JavaScript enabled. Please enable it to continue.</strong></noscript><div id="app"></div><script src="js/chunk-vendors.2d7f5521.js"></script><script src="js/app.fadfe3e2.js"></script></body></html>
TNAS PC notifies the status: Ready. However, authorization via TNAS PC freezes. Windows Explorer opens the system disk, but it is empty.
franco72
Post by franco72 »
How can I do a reset, or install TOS 5.1 cleanly on SD M2 if the system does not boot?
