TOS 5.0.156 (x.86) is Released for Update
Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Fixed some issues of file manager.
2. Fixed some issues of volume.
3. Fixed some issues of external storage.
4. Fixed some issues of general settings.
5. Fixed some issues of user group.
6. Optimized some settings of backup.
7. Optimized some settings of remote access.
Important Notes
1. This update is only for TOS 5.0.120 or later versions. If your TOS version does not meet the requirements, please upgrade to TOS 5 by reinstalling TOS.
3. If you have installed the VirtualBox application, you need to uninstall it and then update the system.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.156 (md5:d4e82f3806f2ec493dc568d08dcdd5df)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.156, you need to update your current TNAS PC to 5.0.33 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.33 for Windows OS
2. TNAS PC 5.0.33 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to pm(a)terra-master.com
Hobba
Re: TOS 5.0.156 (x.86) is Released for Update
Post by Hobba »
hey guys, still an issue with the user/usergroup permissions(get here by going edit/permissions), it will try display 10 objects in a list big enough for 6 and makes the 7th item unselectable
MisterXY
Germany
Post by MisterXY »
I have also the Permission Error with usbshare2
TMLyy
Post by TMLyy »
{L_BUTTON_AT}Hobba
Do you have invalid permissions to edit users and user groups?
TMLyy
Post by TMLyy »
{L_BUTTON_AT}Hobba
Can you send us a screenshot of the invalid edit permission?
gretor
Post by gretor »
Hi Hobba,
I have the same issue with Firefox Browser. Use Google Chrome now, and for me it works !
lg gretor
Hobba
Post by Hobba »
{L_BUTTON_AT}Hobba
What browser are you using? It is currently found that Firefox will have this issue and will be fixed in the next version.
Hobba
Post by Hobba »
@TMSupport
latest version of firefox, sounds great :)
Thanks!
