TOS 5.0.144 (x.86) is Released for Update
Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Fixed some issues of shared folders.
2. Fixed some issues of users.
3. Fixed some issues of the app center.
4. Fixed some issues of media indexing.
5. Fixed some issues of volumes.
6. Fixed some issues of external storage devices.
7. Fixed some issues of storage pools.
8. Fixed some issues of SSD cache.
9. Optimized some settings of hard disk detection.
10. Optimized some settings of backup.
11. Optimized some settings of restoring system configuration.
Important Notes
1. This update is only for TOS 5.0.120 or later versions. If your TOS version does not meet the requirements, please upgrade to TOS 5 by reinstalling TOS.
3. If you have installed the VirtualBox application, you need to uninstall it and then update the system.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.144 (md5: babea52029ebef13db3246caf404e59e)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.144, you need to update your current TNAS PC to 5.0.27 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.27 for Windows OS
2. TNAS PC 5.0.27 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to [email protected]
R4nd0m
Re: TOS 5.0.144 (x.86) is Released for Update
Post by R4nd0m »
As per 5.0.135 still no volume mounted after update
EgorA
Post by EgorA »
The same as on 5.0.135 - CPU usage above 90%
https://imgur.com/a/Zxf7kfS
Charlie_Croker
Saudi Arabia
Post by Charlie_Croker »
Installed on F2-422 with no issues so far.
CPU usage slightly high at present with a number of Postgres tasks (one hitting 32.64% CPU)
Java (18.05%) and Media Index (15.06%)
{L_BUTTON_AT}R4nd0m
1. Log in to the SSH. 2. Execute the command.
df
3. Send us a screenshot of the information.
{L_BUTTON_AT}Charlie_Croker
After updating the system, the programs are restarting, please wait for a while.
R4nd0m
Post by R4nd0m »
{L_BUTTON_AT}R4nd0m
TMSupport wrote: > > > 1. [url=viewtopic.php?f=78&t=2350]Log > in to the SSH.[/url] > 2. Execute the command. > [code]df[/code] > 3. Send us a screenshot of the information. https://1drv.ms/u/s!AqKeBJZCL5XpmaFjZZ5fXHdRKzhqnA
titanrx8
Post by titanrx8 »
Updated from 4.0.130 to 4.0.144 on F2-221. System has one WD Red 6TB EXT4. Media indexing was disabled immediately after logging in (read previously that it was enabled by default and I don't need it for this system which is only a backup server for my other f2-221).
The update went smoothly and the files are accessible. BUT, CPU utilization is still at 100%. There are 69 instances of the postgres process using all of the cpu. This is unchanged from the 4.0.130 rev.
Is there a way to change the file system from EXT4 to BTRFS in order to take advantage of the new snapshot capability?
alesor
Post by alesor »
F2-220
All the programs installed from the "app center" no longer work. For instance:
- Docker (in "app center" I press "active" and I get the error "operation failed")
- Apache Tomcat, as above
- MySQL, as above
and other program.
I have to uninstall the programs, reinstall them and redo all the configurations, hoping it works as before.
Wasted time to reconfigure everything.
Are you aware that some people use your NAS for work?
Please do better testing before releasing versions that create even more problems.
