TOS 5.0.130 (x.86) is Released for Update
MisterXY
Germany
Re: TOS 5.0.130 (x.86) is Released for Update
Post by MisterXY »
Have you change the permission from folder for plex?
for jellyfin i must also change the permission. To do this I had to change the user group and not the user.
Have upload a picture.
https://prnt.sc/goM8tYmyPdTh
Charlie_Croker
Post by Charlie_Croker »
@danielv wrote:
> Hello.
> I have been waiting several weeks to see if certain errors are corrected
> since I updated to TOS 5, but since I see that they are not, I explain them
> here:
> Since the last PLEX updates, I am not able to see my folders where I have
> the media items.
> To be able to explain myself, in my case they are in
> Volume1/Public/Multimedia/Films.
> Well, from Plex, I can only access Volume1/Public and according to Plex
> Explorer, the folder is empty. (Like the rest of the folders on the server,
> which I can access up to the first level, and they appear as empty).
> On the other hand, one of the most used features was to create shared
> folders on the server. I sent the link to my clients and everything was
> perfect.
> Well, since I updated to TOS 5, I have never been able to use this. It
> always failed, for whatever reason, and has never worked properly. After
> the last updates, when I send the link, the first thing is that the browser
> gives an error for the certificate and for not going in HTTPS.
> If you sign in and try to download the shared files, you always get the
> same error:
> "internal error"
> If you have any help, it will be appreciated.
> Best
Go to Control Panel/User Group and make sure that the group called System Media Group has Read/Write permissions and Plex will work. (I had the same issue).
calamariring
Post by calamariring »
Hi ! I just got my F5-221 and got 5.0 installed. And then I just realised the Android app is not working. I read that a couple of months ago, the beta iOS app is out and Android will be available soon.
I can't find any links for these 2 apps. I saw the PC and MacOS ones but I don't really need those.
Thanks.
Charlie_Croker
@calamariring wrote:
On android I tend to use Foldersync which auto backup folders to the NAS. and File Explorer , both work brilliantly with TOS5.0
https://play.google.com/store/apps/deta ... n_GB&gl=US
danielv
Post by danielv »
[quote=Charlie_Croker post_id=19876 time=1658073452 user_id=2281]
@danielv wrote:
> Hello.
> here:
> the media items.
> perfect.
> same error:
> "internal error"
> Best
[/quote]
Hi!!
I don't have media group, (don't know why). I only have admin and allusers.
I try to reinstall Plex, but nothing.
{L_BUTTON_AT}danielv
If your system was updated from an earlier beta version, it is recommended that you reinstall the latest TOS 5.
andrewloz
Post by andrewloz »
Hi, I have tried several times to create an SSD cache, and every time the cache creation fails with 5.0.130. Any suggestions as to how to resolve this issue? Is it possible to create a cache using the command line?
{L_BUTTON_AT}andrewloz
Please update to TOS 5.0.144.
