TOS 5.0.128 (x.86) is Released for Update
Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422, F2-423, f4-423, T6-423, T9-423, T12-423;
1. Optimized some settings of remote folders.
2. Optimized some settings of system information.
3. Fixed some issues of TFM.
4. Fixed some issues of external storage devices.
5. Fixed some issues of SSD cache.
6. Fixed some issues of shared folders.
7. Fixed some issues of user group permissions.
8. Fixed some issues of file management.
9. Fixed some issues of TOS desktop.
10. Fixed some issues of media index.
11. Fixed some issues of hard drive.
12. Fixed some issues of hot spare.
13. Fixed some issues of data scrubbing.
14. Fixed some issues of SSD TRIM.
Important Notes
1. This update is only for TOS 5.0.120 or later versions.
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.0.128
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
Important Note:
After updating to TOS 5.0.128, you need to update your current TNAS PC to 5.0.27 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.27 for Windows OS
2. TNAS PC 5.0.27 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to [email protected]
MisterXY
Germany
Re: TOS 5.0.128 (x.86) is Released for Update
Post by MisterXY »
Media Index is deactivated again after a restart and thumbnails are not displayed even though it was activated.
Charlie_Croker
Saudi Arabia
Post by Charlie_Croker »
Thank you for giving us details of what has been updated.
Also there's a good review of TOS5.0 here https://www.youtube.com/watch?v=OcckiZrgAD4
Most of the issues will be fixed in the coming two weeks.
maxmatech
Post by maxmatech »
Hello!
Last night Update 5.0.126 to 5.0.128.
After Update: I no longer had access to the web interface.
SMB working fine.
I Type: http://193.168.124.121
response
(Changed to) http://193.168.124.121:8181/
193.168.124.121 has rejected the connection.
Portscan at 193.168.124.121 (no open Port 8181)
tested with different web browser : Yes
Check with different Computer: Yes
Check with Linux: Yes
Check with Windows 10: Yes
TNAS Windows Sotware (last version): no access
a brick?
kenfrog
Post by kenfrog »
update downloaded and Nas rebooted
checking and the shares are working still
plex is working but pending updates
checking file access and folders at \\IP\ - works
So far the F5-422 and TOS 5.0 have been working fine - thanks for the updates : )
kenfrog
Post by kenfrog »
maxmatech wrote:
> Hello!
> SMB working fine.
> response
> a brick?
I was having the same issue with the web interface - using http & https default ports and custom ports
Noticed that https://IP:customport/ gets the Loading..., please wait! page
https://IP:customport/tos/#/ gets the blank page like its trying to load
after 30 mins or so, the login page works again - GoodOl' Terra Master Logo and everything : )
noticed that the Telnet port that i set active and to a custom port not 9222 worked after the OS finished it's reconfigure process/re-jigging in and the web interface started working again
joka388
Austria
Post by joka388 »
maxmatech wrote:
> Hello!
> SMB working fine.
> response
> a brick?
Same here for me, no access to the web interface but SMB working.
Its the first time that i have no access after an update.
I wait more than one hour but still no access.
What can i do?
What did you see when you input the ip address of your tnas in the web browser address bar? Loading..., please wait!?
If yes, please wait for a while, the system may be checking your file system and mounting the volumes.
By the way, what is your TOS version before you update it to 5.0.128?
joka388
Austria
Post by joka388 »
The TOS Version before was 5.0.126 and i see a black screen with "the website is not available", "192.168.1.90 rejected the connection"
But SMB is still working.
