TOS 4.2.28(X86) is released for update
TOS 4.2.28 (X86) Release Notes
Applicable models: F2-220, F2-221, F2-420, F2-421, F2-422, F4-220, F4-221, F4-420, F4-421, F4-422, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422
This update includes the following bug fixes for the previous version and new features:
1. Added pam authentication mechanism for SSH, Telnet, AFP, and FTP;
2. Fixed the vulnerability of php encryption;
3. Fixed the issue of Windows Backup;
4. Fixed the issue of HDD hibernation;
5. Fixed the issue of SSD cache;
6. Fixed the issue of SMB password setting;
7. Optimized the fan control.
Important Notes
1. This update is only for TOS 4.2.01 or later versions. If your TOS is 4.1.27 or an earlier version, please refer to here.
3. If you are running vbox in TOS, please update the vbox before updating 4.2.28, otherwise, your system will fail irreparably!
VirtualBox download link
How to update your TOS?
Online update:
1. Go to TOS > Control Panel > General settings > Software update;
2. Check the option "Online update", click "Apply";
3. Follow the prompt to finish the update;
Issue report
If you encounter issues during use, please report to TerraMaster's official forum “TOS update”.
Important Notes
Online update:
Issue report
- crisisacting
- Silver Member
Re: TOS 4.2.28 is released for update!
Will this also be released for the 210 series (ARM)?
The majority of those fixes should be applied to that series as well, especially the PHP exploit that's leaving devices vulnerable to attack/being compromised.
Additionally, if there's a kernel update in this or any updates (past, present & future), can that be indicated in the changelog with full version/point release numbering as it is quite pertinent information.
Please be more transparent with these updates, so further development on your platforms can flourish & exploit resolution can be resolved by the community alongside your internal team, when/where possible.
As per this post: viewtopic.php?f=28&t=2887#p15805, Please indicate if previous patches are integrated, as was stated in said post by TMRyan
Hi! Updates for ARM will be released as soon as possible, please wait.
All updated parts of the system are already indicated in the release notes, nothing needs to be hidden. Once again, all TOS updates will include past patches.
- crisisacting
- Silver Member
It's denoted in the simplest of details; if further details can be indicated, this may be preferred by select users.
If having this simplified changelog with an expandable verbose one is possible (such that those that want the minute details, can access them), this could be great for all.
Every patch has been an out of band release, so just adding a line indicating that this release has Patch 1.18 + 1.24 (x64) integrated, will avoid inquiries about applying said patch(es).
- REBELinBLUE
Have you actually fixed the underlying issue though, user input being passed to system/shell_exec with no validation?Fixed the vulnerability of php encryption
And what about the F4-210 which also have the issue
Am I blind? Where is the link to the download that's usually present?
- Gandalf1369
I found it in the "Download" section of their website. . . . Perhaps they just forgot to include the link when posting in the forum.
{L_BUTTON_AT}Tricky
Hi! Please go to Control Panel > General settings > Software update and select "Online update".
Wow! You have sorted online updates out
