TOS 4.1.18 + F2-221 some issues.
Permissions, domain/LDAP, power, security, notification and more.
andylee
Post by andylee »
Can't set network interface MTU.
Can't disable upnp & bonjours, it auto appear after reboot.
With the SMB shared folder, why do I have to enter the user/pass even though allusers have read/write permission? Tested on windows 10.
Re: TOS 4.1.18 + F2-221 some issues.
Not so sure about "Can't set network interface MTU", could you advise more detailed information?
About enabled upnp and bonjour service after rebooting, it may be the problem of 4.1.18, it will be fixed in later version.
As for entering password and username, only the firsr\t login to the server is needed, and no need to enter password when accessing folders.
andylee
Post by andylee »
TMSupport wrote: 05 Mar 2020, 11:54 Not so sure about "Can't set network interface MTU", could you advise more detailed information?
Means I need to adjust the nas mtu, example 9K mtu. I don't see any option to allow that.
Scrums
Post by Scrums »
andylee wrote: 06 Mar 2020, 11:16
https://www.cyberciti.biz/faq/how-can-i ... interface/
