Hardfecx wrote: ↑26 Dec 2021, 04:40
you all have the chance to try TOS5 an don't use it? I Have an ARM Nas and I have to wait... shame on you!
What a crock.
Just f**** yourself....
How should the most of bugs fixed when nooene test it to report what is working and what not??
Here we go...
I hope you're aware that this is a voluntary program and we're not responsible for beta testing. Just because we can participate doesn't mean we should or have to. Terramaster itself is responsible for its software and has beta testers themselves. So please calm down, walk a mile, and stay civilized.
OK posting here as I was in the first round, got the new update through today and Just tried to install the new version just the same as the last version, but I get to manually load the update, but it won't!
Also, the update downloads as a zip file rather than a TOS package with the TM logo so is this the problem?
Going to go back to the last version for now, also noticed that I couldn't back up the system config on the last version.
OK just checked and the file type is different from the original the first was an INS file and this is a BZ2 file the older INS obviously loads fine but not the BZ2?
OK it would help if you guys used the correct instructions for this in your email, you actually sent instructions to download the file and do a system wipe and install the same as the original TOS5, but this is actually an update which is installed to the original TOS5 system, that way we wouldn't be wasting time trying to reinstall the system and find it won't work!
Tricky wrote: ↑08 Jan 2022, 00:17
Further to my last post about the wrong instructions being supplied with the recent update, i have now observed that on adding a new HDD that it's now stuck on 100% creating a new storage pool.
Ciao Guys,
probably I'm wrong ..... do you manage in accessing NFS TOS share from others pc in your local network?
I'm able to mount but not to access the shared content .....
Thanks for the feedback
So, I've managed to break the beta apps, like most of them and can't get them to install through the web UI, anyone know where on the FS the logs might be that would indicate why? or perhaps what command line tool is used to install a tpk?
