F2-421 Discontinued?
PhillipB
Post by PhillipB »
Hello everyone
When looking on the website for downloads and support for the Terramaster F2-421, it seems to be absent from the list of available products.
Is there a reason for this? Was it discontinued?
Searching on the forums hasn't found me any concrete answers. It's often referenced, but I can't find any update information on it anywhere.
Do I treat it as another model instead?
F2-421
Re: F2-421 Discontinued?
F2-421 has been upgraded to F2-422, if you are looking for quick guide or some other apps or software, you can refer to model F2-422.
PhillipB
Post by PhillipB »
Thank you for your quick response. So that means the F2-421 uses the same software and updates as the F2-422?
If that's so, my only bit of feedback would be to add the F2-421 back to the downloads menu, with a page simply stating the F2-421 uses the same software as the F2-422, preferably with a link to the F2-422 downloads page for quick access. That would clear up a lot of confusion for anyone else with the same model.
Thank you.
F2-421
Will report to the product team, thank you!
