TOS Patch1.06 for ARM/X86 models for TOS4.2.06~4.2.09
Update notes for TOS_PATCH_ARM_1.06
Release Notes:
. Fixed vulnerabilities in Rsync;
. Fixed vulnerabilities in UPnP;
Applicable models:
ARM:
F2-210、F4-210
x86:
F2-220、F2-221、F2-420、F2-421、
F4-220、F4-221、F4-420、F4-421、
F5-220、F5-221、F5-225、F5-420、F5-421、F5-422、
F8-421、F8-422
Applicable TOS
TOS4.2.06, TOS4.2.07, TOS4.2.08, TOS4.2.09.
Download link:
For ARM models: https://download2.terra-master.com/TOS_ ... M_1.06.bz2
For X86 models: https://download2.terra-master.com/TOS_ ... 4_1.06.bz2
How to install the patch?
1. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Manual Update”;
2. Click "Browse" to select the downloaded patch package;
3. Click "Apply";
sianderson
Re: TOS Patch1.06 for ARM/X86 models for TOS4.2.06~4.2.09
Post by sianderson »
perfect upgrade thank you nice and simple
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
shabbirh
Post by shabbirh »
Thanks this updated worked perfectly (F4-210 (ARM)).
Just wanted to make a quick point for any one else who once the NAS comes back on line find that their shared folders are unavailable. This is because you have chosen encryption (always a good thing). You just need to go into the Web Interface and enter the encryption key/password for your given share and it will mount.
Thanks again, and looking forward to the upcoming 4.2.12 update (for ARM).
Peace
Gandalf1369
Post by Gandalf1369 »
Installed the 1.06 (X86 version) patch on my F4-220 running the latest TOS 4.2.09. Smooth and quick upgrade with no problems. Thank you . . .
pinuk
Post by pinuk »
The link seems to be unavailable, is there an alterative download location for this?
Thanks.
{L_BUTTON_AT}pinuk
The link is available, you can try to check the network, browser settings or firewall.
sc351
Post by sc351 »
This patch would render my f4-210 TOS UI useless after about 10 minutes. I've reverted back to patch 1.04 and operation is back to normal.
sianderson
sc351 wrote: ↑05 May 2021, 21:18 This patch would render my f4-210 TOS UI useless after about 10 minutes. I've reverted back to patch 1.04 and operation is back to normal.
thats interesting my F2-210 has been running for 24 days straight without any problems with this patch, what kind of things do you run on it? i have DLNA Media Server, One Drive and USB Copy
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
victorjhg
Post by victorjhg »
Yesterday I installed the update on an F5-422 with 4.0.9-P1.04 and since then I have a nice "502 - Bad Gateway" error. No access to the web locally or to files remotely. Nice job. To reinstall ...
victorjhg
Post by victorjhg »
victorjhg wrote: ↑06 May 2021, 16:31 Yesterday I installed the update on an F5-422 with 4.0.9-P1.04 and since then I have a nice "502 - Bad Gateway" error. No access to the web locally or to files remotely. Nice job. To reinstall ...
Ok, I was going to reinstall the system following the instructions available at viewtopic.php?f=75&t=423 and at the beginning of the process indicates that the data on the HDDs will be erased. Please help!!!
