TOS4.2.07 is released for updating !
TOS4.2.07 (ARM) Release Notes
Applicable model: F2-210, F4-210.
This update includes following bug fixes for the previous version, new features and optimized user interface:
1. Fixed the issue that the files transferring speed is slow when NFS mounted to Windows system;
2. Fixed the issue that the Beta module will be opened automatically under TOS Application center;
3. Fixed the issue about the incompatibility of Rsync backup when TNAS is set as Rsync client;
4. Fixed the issue of garbled characters when unzipping zipped folders which includes Chinese files;
5. Optimized the UI patterns at TOS Control Panel.
6. Fixed some system vulnerabilities.
TOS4.2.07 (X86) Release Notes
X86 models: F2-220, F2-221, F2-420, F2-421, F4-220, F4-221, F4-420, F4-421, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422.
Important Notes
This update is only suitable for TOS 4.1.27 or above.
This update is not suitable for TOS4.2.X Beta.
After updating to TOS4.2.07, the following services SMB, CIFS, AFP, FTP, Telnet, SSH, UPnP and Bonjour would be enabled automatically.
How to update your TOS?
1. Download the update package:
For X86 models: https://dl.terra-master.com/cn/TOS_S2.0 ... 241608.bz2
For ARM models: https://dl.terra-master.com/cn/TOS_A1.0 ... 241608.bz2
2. Go to TOS> Control Panel> General Settings> Update & Restore, and click “Manual Update”;
3. Click "Browse" to select the update package;
4. Click "Apply";
How to reinstall TOS?
Installation package link:
For X86 models: https://dl.terra-master.com/cn/TOS_S2.0 ... 241608.ins
For ARM models: https://dl.terra-master.com/cn/TOS_A1.0 ... 241608.ins
1. Log in to TOS and go to TOS Desktop> Control Panel> General Settings> Update and Restore> Backup and Restore;
2. Tick "Backup system configuration" to back up your system configuration;
3. Go to TOS Desktop> Control Panel> General Settings> Update and Restore> Restore to Factory Default;
4. Tick "Restore to factory default", and then click "Apply"; your system will be erased, but the data on the hard drives will not be deleted;
5. Refresh the browser page, and follow guide on the page to install a new TOS;
6. If the page refresh fails, please use TNAS PC to search for your TNAS device; Then select the device and click "Login"; Follow the web page to install the new TOS;
7. After the system installation is complete, log in to TOS and go to TOS desktop> Control Panel> General Settings> Update and Restore> Backup and Restore to restore your backed up system configuration.
Issue report:
If you encounter issue during using, please report to TerraMaster official forum “TOS update”.
Important Notes
4. Click "Apply";
Issue report:
- sianderson
Re: TOS4.2.07 is released for updating !
who is going to be the first guinea pig then? at the moment my 4.2.06 is stable so I am waiting for other reports on this update
F2-210
4.2.31
4.2.31
Learn't my lesson i am sticking with 4.1.30 for the time being and my friend is still stuck with the beta version until another beta comes out or there is an upgrade path from the beta to the main version.
What the heck....for us that upgraded to the 4.2.05 beta we are still stuck and unable to upgrade to a stable release?
When are we going to get an uograde path?
I don't minf being a beta tester but not getting an upgrade path is just wrong.
Please advise.
Please advise.
The update was without any problems on my F4-210 (ARM) from 4.2.06 to 4.2.07.
Updated from 4.2.06 without issue on my F2-220
- sianderson
so yet again im restoring all my data from the backup USB drive
17 days of my F2-210 being up and working solidily, I do the update to 4.2.07, it reboots flashes my HDD1 light like mad and then just freezes the unit (HDD1 light goes out), reboot same thing happens again, even tried the boot without drives in trick but as soon as I dropped the drive in it would freeze the unit
its probably my own fault as I have noticed there is a message on the admin portal website when initialising about barracuda hard drives which is the one I am using
i now have a 500gb hard drive in HDD1 which I understand TOS is now installed on and running and my 6TB Baraccuda in HDD2 which I hope is now just seen as a data drive, to see if that will give me a more stable operation (my long term goal is to have matching 6TB hard drives in HDD1 and HDD2 in a raid array, backed up to a USB drive, its just a case of affording the hard drives (glad i didn't buy 2 barracudas now)
F2-210
4.2.31
4.2.31
[OK] Update done successfully
[OK] Docker still working and autostart all containers
[Fail] Remote Share mount continues without permissions
For now is that I try ...
TOS4.2.06->4.2.07
F5-221 - 10G - 4x4TB - Raid5
TOS4.2.06->4.2.07
TOS 4.2.09 + TOS_PATCH_X86_1.04
F5-221 - 10G - 4x4TB (WD Red Pro) - raid5 (btrfs)
Docker containers with docker-compose, managed with portainer
You can follow the instructions below to reinstall to TOS4.2.07.Post by UncleJohnsBand » Yesterday, 19:59
Please advise.
