Plex folder not in appdata
willavery
Post by willavery »
I just did a hard reset and wipe of my whole system, and am now working to reinstall things. I have my old Plex library files, which I want to replace the new Plex folder created by the fresh install. Only I can't find the new folder--it is not in the appdata shared folder at all. It was supposed to install into Volume #1, where the appdata folder is sitting, but there's nothing there. I "restored" the appdata shared folder to the other volumes, just in case something got lost there, but they were also empty.
Is there a setting I need to enable to be able to see application data in either the File Browser or connected to my computer?
willavery
Re: Plex folder not in appdata
Post by willavery »
TL;DR I found the Plex folder, however, I can't mount it on my MacBook via AFP in order to replace the library files, since it's not in a shared folder.
