F5-221 RAM upgrade Specifications
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
OttoG
Post by OttoG »
The F5-221 is expandable from 2GB to 10GB.
Nowhere in the supplied documentation or the online compatibility chart can I find the specifications for compatible RAM upgrades.
I'm looking to expand to the full 10GB.
As such, I would appreciated advice as to the correct RAM to purchase.
Thanks in advance.
Re: F5-221 RAM upgrade Specifications
Please search in our Amazon shop. Here is the link for your reference :https://www.amazon.com/dp/B06ZYRJVQ1/re ... UTF8&psc=1
KoGa
Post by KoGa »
Hi, I have a related question. There seems to be conflict from different sources on what the actual maximum RAM is thst can be installed. Can you please clarify?
KoGa wrote: 23 Sep 2020, 00:51 Hi, I have a related question. There seems to be conflict from different sources on what the actual maximum RAM is thst can be installed. Can you please clarify?
No matter what TNAS model, the RAM expansion slot supports up to 8G.
KoGa
Post by KoGa »
Thanks, so I can go ahead and install DDR3 SDRAM 8GB, 1,600 MHz, 1.35V.
ogoflowgo
Post by ogoflowgo »
So, did you? And did it work out?
JayBlingham
Post by JayBlingham »
I can confirm that I installed an 8GB SODIMM DDR3L 1600Mhz into my F5-221 and it has been working flawlessly. I actually had one lying around from an old laptop.
Jay
F5-221, 5.0.171-00221
DiscoSi
Post by DiscoSi »
Sorry to be the bearer of bad news but the processor in the F5-221 cannot address more than 8GB of total ram:
https://ark.intel.com/content/www/us/en ... 5-ghz.html
It won't do any harm, as far as I'm aware, but just be aware that any system ram above 8GB is probably being wasted.
JayBlingham
Good to know, thanks DiscoSi. Now I'm going to need to find a way to test that ;) I'm fine if it only actually uses 8GB - the ram I had was just lying around anyway, but it would be fun to test it.
Jay
JayBlingham
According to this, the system supports up to 16GB of memory - but since the first 2GB are soldered onto the board, the max would be 10GB. I'm not disputing any documentation for the CPU that says otherwise. I'm just reading the output of the dmidecode command in Linux.
[root@tmnas~]# dmidecode -t 16
# dmidecode 3.1
Getting SMBIOS data from sysfs.
SMBIOS 3.0.0 present.
Handle 0x002D, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 16 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Jay
