F5-420 RAM module
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
erik.meuwese
F5-420 RAM module
Post by erik.meuwese » 02 Jan 2021, 20:21
The compatibility list shows only TerraMaster KBM400 4GB as compatible with the F5-420. This module is not available in European stores. I understand that TerraMaster can not test every available module.
For me the Patriot Memory module PSD34G1600L2S 4GB DDR3L works great in my F5-420. It fits in the case without any modifications. May be this could be added to the compatibility list.
The pdf data sheet is in the attached zip.
Patriot_Memory_PSD34G1600L2S.zip
(103.1 KiB) Downloaded 42 times
justsimon
Re: F5-420 RAM module
Post by justsimon » 13 Jan 2021, 05:59
I wish I'd known this before buying the Terra-Master RAM.
The Patriot RAM is about 1/4 the price!
TMS
Customer Service
Post by TMS » 13 Jan 2021, 18:21
erik.meuwese wrote:
02 Jan 2021, 20:21
Thanks,it cannot be added to our compatibility list.
Because the quality of the memory module seriously affects the performance of the device, non-original memory modules have not been tested and certified , they are not recommended.
crazy72
Post by crazy72 » 24 Feb 2021, 19:17
Hi
Did someone know if a 8GB Module is compatible with F5 or F4 nas ?
I tried 3 different DDR3L modules (8500, 10600, 12800) without success.
I will do the last test next week with a module with only one line of chips.
This is useful in case of using it with Virtual PC.
Chris
DiscoSi
Post by DiscoSi » 24 Feb 2021, 21:48
I've got one of these in mine and it works ok with TOS.
Crucial RAM CT102464BF160B 8 GB DDR3 1600 MHz CL11
I say it works ok with TOS, but I did post previously that my F5-221 BIOS doesn't populate it in the system DMI table which does seem to prevent some 3rd party operating systems/programs from being able to utilise the full amount of memory. Is that the issue you've experienced? Or does TOS not recognise it at all?
My previous post:
viewtopic.php?f=71&t=1302&p=6697#p6697
justsimon
Post by justsimon » 25 Feb 2021, 11:53
crazy72 wrote:
24 Feb 2021, 19:17
Hi
Chris
There have been a couple of people saying they've put 8GB sticks in, but I did see a comment somewhere to check the CPU manufacturer site. As some CPUs can only utilise a max of 8GB.
Mine's stock with 4GB (F5-420) and the CPU only supports up to 8GB total according to Intel.
Tricky
Post by Tricky » 25 Feb 2021, 19:03
I am running 8gb RAM in one of my F5-221 so 10gb total.
justsimon
Post by justsimon » 26 Feb 2021, 06:05
Interesting, does it show 10GB in the TOS UI?
I have no idea how to test if the CPU/system is able to use all the RAM.
According to Intel, that CPU supports up to 8GB (reference - Celeron J3355)
Mine (F5-420) also supports up to 8GB according to Intel (reference - Celeron J1900)
Dumb dumb here bought the official Terra-Master 4GB stick instead of gambling on a 4GB or 8GB stick by another manufacturer.
I knew that RAM only needs to meet the right specs, and that any brand would do, but I was worried about throwing away ~40-60$AUD
Hammer
Post by Hammer » 12 Jun 2021, 12:55
At least you got RAM that you knew was going to work.
I found Timetec 8GB DDRL 1600 PL200901R#NP24 works too:
The NAS show that it has 10GB - wonder h ow much of that it can actually address.
