I had a raid 1, 2 disk configuration. I added another disk and went to storage pool, upgrade to raid 5 and selected the newly added disk.
After that, I was not able to log into the nas for about 2 hours and then it came back up. I can log in and it shows the storage pool as raid 5 with all 3 disks however the volume size is still the same. I thought going from 2x 12tb raid 1 to 3x 12tb raid 5 would give size of 24tb, however it still shows 12tb.
Is there a way to get it to update/resize without losing the data?
cat /etc/mdadm.conf
ARRAY /dev/md8 metadata=1.2 spares=2 name=TNAS-01472F:UTOSSWAP-X86-S64 UUID=?????
ARRAY /dev/md0 metadata=1.2 spares=1 name=TNAS-01472F:UTOSUSER-X86-S64 UUID=?????
cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [multipath] [faulty]
md0 : active raid5 sdb4[0] sdd4[2](S) sdc4[1]
11713460032 blocks super 1.2 level 5, 64k chunk, algorithm 2 [2/2] [UU]
bitmap: 15/88 pages [60KB], 65536KB chunk
md8 : active raid1 sdd3[25] sdc3[24] sdb3[0]
1998784 blocks super 1.2 [24/3] [UUU_____________________]
md9 : active raid1 sdd2[24] sdc2[1] sdb2[0]
2998208 blocks super 1.2 [24/3] [UUU_____________________]
unused devices: <none>
f4-210 upgrading from 2x 12tb raid 1 to 3x 12tb raid 5
Re: f4-210 upgrading from 2x 12tb raid 1 to 3x 12tb raid 5
Please advise your current TOS version and send an email to support(at)terra-master.com, our engineer will help you with this issue by remote session.
