Hi there,
I connected a USB HDD, formatted as ext4 to my TM F2-420. It shows up as unmounted. How do I mount it?
thanks,
geb
mount USB ext4 HDD
Re: mount USB ext4 HDD
Hi again,
Actually, I figured this out.
I tried to SSH into the NAS with SSH root@ipaddress:portnumber. the port number was 9222, and that did not work for some reason. As soon as I changed the SSH port number to 22, I was able to log in.
I then mounted the disk with
mount -o ro /dev/(disk name) /(directory name)
Thank you for the feedback and glad to know you solved it.
