Hi, I purchased a terramaster FS-221 last week, with TOS 5.1.
I installed 3 x 8 TB drives in the system, created the TRAID, and waited for it to synchronize. I copied 2 TB of data to it after done, and that all works.
I then installed 2 x 3 TB drives into the system. The system sees them. I tried to create a second storage pool from the storage pool control panel menu page using the 3 TB drive, using RAID1 i think After going through the options and clicking create, nothing happened. So, i went to the Volume page in control panel, clicked new, create storage pool from the 3 TB, using raid1 and it started. I saw it synchronizing (note, it called it storage pool 3). I went to bed. I woke up in the morning, the alert says the RAID #1 completed; however, I can only see storage pool 1 in the list. I thought maybe it failed, but I can't see any errors. It also will not let me click on Create new anymore. Under Hard Disks, it shows all 5 still, and none as empty.
So, where is the other storage pool? How can i get it back or even just start over on those 2 hard drives when I can't see the pool?
I'm re-copying over my 2 TB of data to another location in case i have to wipe everything out and start over, but I'm hoping this isn't the case, because how often does this happen? I don't have enough storage space elsewhere if I had to do this with the 14 TB of data that I'll eventually have.
Thanks!
Can't create and see 2nd storage pool
Re: Can't create and see 2nd storage pool
This happens when using an incompatible hard drive. Please check whether your hard drive model is listed in the compatibility list.
- Rillithain
All 5 drives are on the list of compatible drives
WD80EFZZ are the 8 TB
WD30EFRX are the 3 TB
- Rillithain
I tried to edit my last post, but don't see a way..
This is what lsblk is reporting.
sdd 8:48 0 2.7T 0 disk
|-sdd1 8:49 0 285M 0 part
|-sdd2 8:50 0 7.6G 0 part
| `-md9 9:9 0 7.6G 0 raid1 /
|-sdd3 8:51 0 1.9G 0 part
| `-md8 9:8 0 1.9G 0 raid1 [SWAP]
`-sdd4 8:52 0 2.7T 0 part
`-md1 9:1 0 2.7T 0 raid1
sde 8:64 0 2.7T 0 disk
|-sde1 8:65 0 285M 0 part
|-sde2 8:66 0 7.6G 0 part
|-sde3 8:67 0 1.9G 0 part
`-sde4 8:68 0 2.7T 0 part
I don't mind starting over this time since i have everything backed up, but, i'm worried that these drives will still be reported as full.
Should I secure erase them both and try again?
2nd question. If I removed the storage pool on the 3 x 8 TB, and made one big storage pool of all 5 disks, is it going to give me more than the value of the 3 x 8s, or no since the 3 TB drives are smaller?
After backing up the data, you can re-create them. First, you can re-insert the hard disk that cannot display the storage pool under the power-on state, and then create a non-protected array. After deletion, you can re-create the protected array.
When making a storage pool with five disks, the value is different when selecting different array types. You can decide whether to create a protected array or a non-protected array, one array or two arrays according to the importance of your data. If you choose non-protected array, you will have more storage space. If you choose protected array, your data will be more secure.
- Rillithain
OK, i wiped everything out, used fdisk and removed all the partitions on those 2 drives, then deleted the first volume and storage pool i had created, and started over. Now i have 22 TB traid that uses all 5 disks.
From what I've been reading, if my terramaster device fails, the only way I can access the data, is through another terramaster of the same model, right?
