Change Raid | Can't Delete Storage Pool
xpesrx
Post by xpesrx »
I have a new TNAS and in setting it up, I ended up with a RAID 5. Now, before anything is on the nas, I am trying to change my RAID from 5 to 6.
I delete the volume then I go to delete the storage pool but as soon as I do, it pops back up? Edit and Create are grey'd out.
Please advise.
Re: Change Raid | Can't Delete Storage Pool
When you delete a storage pool, what is prompted?
You need to delete the storage pool before creating a new RAID.
xpesrx
Post by xpesrx »
No prompts. It does tell me something about nothing being saved and to confirm leaving when I tell it to delete the volume but I dont see a button where I can save what I've done (deleting the volume) anywhere. See video here: https://youtu.be/DxfZ0IedRmU
Please try to restart the TNAS and delete again.
xpesrx
Post by xpesrx »
I've tried this multiple times
xpesrx
Post by xpesrx »
still not working
Try to delete volume via SSH terminal.
1. Log in to the SSH
2.
df
3. Unmount volume 1 and /home
umount  /mnt/md0
umount  /home
4. Delete /vg0-lv0
lvremove /dev/mapper/vg0-lv0
thefalloftroy101
Post by thefalloftroy101 »
Hello, I am experiencing the same issue where I cannot delete a Volume (which means I also cannot delete a Storage Pool) on my TNAS (F5-421).
I have followed your instructions above to login using SSH, but when I try running this command:
umount /mnt/md0
umount /home
I get this error message in Putty:
umount failed: Operation not permitted.
Can you please help me to be able to delete my Volume?
{L_BUTTON_AT}thefalloftroy101
If you are using TOS 4.x, you need to switch to the root user to execute the command.
sudo -i
