free space to leave for backup drives
robertkwild
Post by robertkwild »
hi all,
i have a RAID 6 configuration 4x4tb=8tb and when i do a "df -h" on my esxi server it says it has 7.2TB, is it wise to fill up all of it ie all 7.2TB, wont the disk degrade as is it best to have some free space so it can run more efficiently
thanks,
rob
Re: free space to leave for backup drives
Some storage space needs to be reserved so that the system and applications can run and update normally.
robertkwild
hasnt terramaster NAS got its own disk for its OS, wouldnt there be free space there
im talking about the 3.5" drives ive put in for the backups and i assume the terramaster NAS wouldnt be running of the drives ive put in, i assumed it had another disk inside for the OS to run off
TMwuu
Post by TMwuu »
{L_BUTTON_AT}robertkwild
Because of the base system, the hard disk manufacturer calculates the capacity of the hard disk according to the decimal system of thousands, that is, every thousand is entered into an order of magnitude unit, but the computer is binary, and the binary of every thousand is 1024, which is equivalent to 1000 in decimal. , so the actual capacity of the 8T hard disk is 7.27TB, and the theoretical capacity is 8T.
