Good evening I write from Italy ...
my name is Angelo
some time ago I bought a TerraMaster NAS F2-210
inside I inserted Western Digital WD Red HDD Internal 6000 GB, SATA III, 6000 Mb / s, 5400 RPM, 64 MB, 3.50 Inches
so far so good
today however I bought and installed a second HD ... same brand and model ..
the problem is that I don't know how to get it detected by the NAS ....
always tells me that I only have one HD available ...
where did I go wrong????
thank you very much
Problem HD update inserted in slot n°2
Re: Problem HD update inserted in slot n°2
Can you see the drive indicator on or off?
Can you see two drive in this list?
yes...yes
this morning I tried to create a shared folder and finally the system detected it.
I am writing to you in case other problems occur.
thank you so much for now
Hi, storage pool and volume should be created after adding a new HDD. And then you can create folders on the volume to use the HDD.
