Mount exfat drive
Tomonline
Mount exfat drive
Post by Tomonline »
Hi.
Anyone knows how to mount an exfat drive by external usb port on terramaster F2-210
powerQ
Re: Mount exfat drive
Post by powerQ »
TNAS does not support USB drive with exFat file system.
here is the official spec: https://www.terra-master.com/global/pro ... nu&mid=297
Tomonline
Post by Tomonline »
powerQ wrote: 29 Mar 2020, 22:43 TNAS does not support USB drive with exFat file system.
Thanks for your answer. I’ve check the spec you send me. I realize it doesnt mount either HFS+, NTFS or FAT32. Only Ext4.
What can i do?
The spec mentions the external drive can be:EXT3, EXT4, NTFS, FAT32, HFS+
